Help finding cel jumper cable on EM1
Old Feb 5, 2011 | 10:21 AM
romeo_f's Avatar
Default Help finding cel jumper cable on EM1
Hi guys, I just made myself owner of a 99 EM1, im trying to check a cel following the procedure in the faq but as hard as I search around the ecu there's no jumper cable or anything remotely similar, my civic is a canadian version, is there a chance this plug is anywhere else?
Thanks
Old Feb 5, 2011 | 12:07 PM
Former User's Avatar
Default Re: Help finding cel jumper cable on EM1
Did you remove the kick panel covering the ECU? The service connector is usually inserted into a green or blue rubber holder. Click on the CEL sticky.
Old Feb 5, 2011 | 03:08 PM
romeo_f's Avatar
There's a green connector attached in top of the ecu, are you talking about that one? i'll take a couple pics so you can guide me better..
Old Feb 5, 2011 | 03:47 PM
The CEL sticky has a picture of the rubber holder.
Old Feb 6, 2011 | 08:31 AM
romeo_f's Avatar
Ron thanks for taking your time, look I took some pics to show you what I see, If you look closely there's no 2 wire jumper, unless it's hidden somewhere else?
Old Feb 6, 2011 | 08:57 AM
EJ8_Man's Avatar
That's interesting. Are there any wires going behind the ECU? It is typically located above the ECU, maybe it got pushed up into the dash. Here's a pic of mine.
The lighting is crap, but the wires are coming out of the main bundle that plug into the ECU
peanut butter
Jan 10, 2008 09:48 AM
es_squared
Apr 3, 2004 05:05 AM
EKtypeRhaTcH
Jul 9, 2003 01:18 AM
h8tred
Jul 7, 2003 08:35 PM
