CEL help!
CEL help!
my car is a 00 EK. i was driving this morning to the dealer to get some stuff and my cel came on. i just changed my throttle cable yesterday because it became loose. it drove fine yesterday all day. just this morning the light came on. where should i start? any suggestions? also when my cable became loose everytime i press on the gas and let go it squeeks. i changed my cable and my gas pedal was now fine but it still squeeks.
Re: (EKtypeRhaTcH)
pull the kick panel on the passenger side...down by your feet towards the door. under there is your ecu. look for a big green rubbery looking thing...pull the plug out of it and thats the connector you want to use. when you find that...bridge the two holes with a paper clip...make sure it is tight. then turn the key to ignition...but don't start the car. the cel will flash some pretty colors.
Re: (EKtypeRhaTcH)
there should be a small plug down by your ecu. its a 2 wire i believe. anyways, you use a paperclip or wire and connect them, like a loop (hard to explain) turn the key all the way, car doesnt need to be on. the cel will flash several times.
edit: the guy above me explained it much better
this site will tel u which codes your throwing. a long blink is for the tens place and short blinks are in the ones place. ex: 1 long 2 short is 12
http://tech.hybridgarage.com/tech/codes.html
Re: (allmtr)
If you have a Haynes manual, it will also have a diagram of which plugs are being referred to (the ones you have to bridge) and a list of the codes, too.
romeo_f
02-06-2011 08:57 AM
