Intercooler Core For a Radiator?
Just been thinking to myself, has anyone tried using a Ebay Intercooler Core cut the ends off and used it for a radiator?
Only asking as i need to make a very large radiator for my twin engine project ie 1 rad cools both engines.
Or do we think the fin's are to thick an will not cool the water right?
(plus finding it hard to find a aluminum core manufacturer/supplier in the UK)
All comments welcome
Radiators are designed much differently inside than an intercooler. They use smaller thin tubes and a lot of them for more surface area. Why cant you just buy a cheap ebay radiator for a Civic or something?
Yes i agree i could use a aluminum rad and cut that up BUT i would need 2 to get the surface area i am after for cool both the engines, the reason why i asked about intercoolers as they are very large already.
I did think intercooler internals where differant BUT wanted to double check before rushing in a buying items.
wide tubes results in less fin / tube if that makes sense.
Intercooler tubes are typically 6-10mm high, radiator tubes are typically 2-3mm high.
2003, aluminum, core, cores, ebay, europe, good, honda, houstoncom, intercooler, list, manufacturers, pilot, radiator, tech
