coolant reservoir bubbling?
Old Feb 4, 2011 | 05:10 PM
yourboyluigi09's Avatar
Default coolant reservoir bubbling?
well i bought this 99 civic lx for 500 ..very nice except that it was overheating a lot...so i took the thermostat and it was bad..water pump was bad and head was warped because of blown head gasket too..also i flushed the radiator and found chunks of stuff coming out at first but today i flushed it again and it was fine..anyhow i the head back together after being resurfaced and used new head bolts of course..i also checked the compression of the car to see if it was up to specs and 3 cylinders are at 185 psi except cylinder #2 which is at 160-165 ish...so as i drove it today i noticed the reservoir was bubbling like it wanted to overheat but it hasnt and it most likely wont but i asked a friend about the compression and he said the #2 cylinder might have a messed up piston ring scratching up the wall...would that cause the reservoir to bubble like that? or am i missing something else?
thanks in advance
Old Feb 4, 2011 | 05:22 PM
94EG8's Avatar
Seagull Management
Default Re: coolant reservoir bubbling?
Sounds like either the headgasket didn't seal properly or you've got a cracked head or block.
Old Feb 4, 2011 | 05:52 PM
aww great..im going to take it apart maybe this weekend and use that gasket sealer they have..if not its only a d16y7 blocks are like 100 bucks thanks for your time
Old Feb 4, 2011 | 07:30 PM
nothing_shocking's Avatar
Check the radiator cap. My girlfriend's Accord had a bubbling overflow tank but it wasn't overheating. Took the cap off to find that it had fallen apart so that when it was cooling down after it was turned off, it was sucking air. Maybe you'll get lucky like that.
Old Feb 5, 2011 | 01:23 PM
95ProjectEJ1's Avatar
Pop the radiator cap. Is there any "black film" floating around that you can see? Milky oil? White smoke exiting the exhaust?
Old Feb 5, 2011 | 01:50 PM
CivicxTree754's Avatar
Photogenic
Loved
+1 for headgasket
Old Feb 5, 2011 | 05:20 PM
Jimmy's Avatar
Global Moderator
Is the Cooling fan kicking on? Check this first
Old Feb 23, 2011 | 07:36 PM
yea the fan is turning on....and it was just as i thought...the gasket didnt seal right..so i took it apart again and use the gasket sealer this time and now it doesnt bubble as much as it used to...the only thing left i havent replaced was the radiator cap and radiator its self...so if it becomes a problem i know that the coils inside the radiator are clogged somehow or something...but regardless thanks guys for the help!
Old Feb 24, 2011 | 01:26 AM
del sol cal's Avatar
my car had the same problem fixed it with a buddyclub cap i think it had a rating of 1.3 psi no more boiling coolant
greekspeed
Jul 14, 2009 03:51 PM
prelude1911
Jun 5, 2007 07:55 AM
JTCdudeman
Sep 24, 2005 07:23 PM
5thgencivic
Mar 25, 2003 12:46 PM
Lei Siew Long
May 30, 2002 03:32 PM
