help! dropped something into gas tank
Old Feb 4, 2011 | 01:55 PM
sde780's Avatar
Default help! dropped something into gas tank
I was on the phone with my ex, while trying to see if I can put lucas gas treatment into my tank without a funnel. I didn't notice a small plastic cap on the bottle tip and it fell down the filler neck when I pulled the bottle back!
I was wondering if it's ok to let it be or should I pull everything apart to get it out? Is the filler neck easily removed? I dont think it dropped into the tank its still in the filler neck
Old Feb 4, 2011 | 01:56 PM
NOFX's Avatar
H-T White Ops
Default Re: help! dropped something into gas tank
Exactly what fell down there?
When I've put Lucas into a car I just uncap it (bright green cap), peel the plastic/foil/paper seal off and then shove the bottle in like you're pumping gas. I never knew anyone used a funnel.
Old Feb 4, 2011 | 01:57 PM
TwotoneC1Da9's Avatar
its fine theres a filter on the end of the fuel pump, unless you reeeeeeally want to pull it out.
Old Feb 4, 2011 | 02:15 PM
sde780's Avatar
the plastic cap on top of the bottle fell in. Someone said the plastic might melt and clog my injectors or something
Old Feb 4, 2011 | 02:33 PM
NOFX's Avatar
H-T White Ops
Yeah... I don't think I'd want such a large piece of debris in the tank. And in the filler neck it might cause issues with clogging.
If you remove the passenger rear wheel you might be able to see how you're going to remove the filler neck.
Old Feb 4, 2011 | 02:46 PM
mafia's Avatar
X2
Nothing is going to melt in there.
And if you are going to try to take out the cap, good luck.
Old Feb 4, 2011 | 03:42 PM
Samuraij's Avatar
Superfly
did the actual bottle cap fall in? or is it the lining on the bottom of the cap?
Old Feb 4, 2011 | 04:01 PM
sde780's Avatar
its the small cap they put on top of bottles to cap them after you cut the tip off of the bottle... pennzoil syncromesh tranny fluid has the same kind of cap. it's small enough to where next time I fill up it'll be flushed into the gas tank.
I will be boosting this car soon so I'll tinker around and see if I can just take the fuel neck off. if not hope you guys are right and it doesnt melt
Old Feb 4, 2011 | 04:29 PM
dagle's Avatar
well its plastic.. so it'll float.. suppose you could try filling it to the top of the neck and see if it floats up (with a separate gas can). not sure if there's an anti-overfill valve on cars. just a thought.
Old Feb 4, 2011 | 04:41 PM
NOFX's Avatar
H-T White Ops
Oh, so you're talking about the one quart bottles. If you grab one of the smaller one then you'll have a nice little pre-measured bottle that easily pours into the fuel filler btw.
Old Feb 4, 2011 | 04:44 PM
ONeill24's Avatar
if its a newer car it will have a screen in the neck of the gas tank which will prevent the plastic seal from actually getting into the tank. the screen is usually in there so someone cant siphon gas. if you were to get a vacuum cleaner with the attachment thing you could probably get a piece of hose from home depot and attach that to the vacuum and stick the other end of the hose in the tank and slide it down enough to the screen in the neck of the tank, which would get the piece of plastic out. personally i would just leave it in there. its probably never going to cause you a problem.
Old Feb 7, 2011 | 09:00 AM
rimsandthings's Avatar
it should be fine.
Old Feb 8, 2011 | 04:51 PM
ShaneTrain's Avatar
Same thing happened to my friends 96 civic last year, he hasn't had any problems from it thus far.
Old Feb 8, 2011 | 08:20 PM
OEMfanatic's Avatar
ya i wouldnt worry, im sure itll be fine.
Old Feb 9, 2011 | 04:07 AM
1GPlusSH's Avatar
i wouldn't worry about it.
but, if those caps really do float, just fill your gas tank all the way up to the mouth of your tank. it may just float all the way up
r1ch1e
May 24, 2007 11:34 AM
deanh8
14
Dec 4, 2005 10:51 PM
Layziebtnh055
10
Oct 27, 2004 12:38 PM
Hard2Find
Aug 16, 2004 08:47 PM
shming123
Sep 14, 2003 06:51 PM
