what is my body type? 98 4dr ex and where can i find a subframe for it?
Old Feb 4, 2011 | 12:55 PM
muzzeemoto86's Avatar
Default what is my body type? 98 4dr ex and where can i find a subframe for it?
what is my body type?? 98 4 door ex and where can i find a subframe or how can i straighten the radius part that bent from takin a shot on the lower control arm mount?
Old Feb 4, 2011 | 12:58 PM
98civdx's Avatar
Master Detailer
Default Re: what is my body type? 98 4dr ex and where can i find a subframe for it?
Front or rear?
Any 96-00 front subframe will bolt right in.
Old Feb 4, 2011 | 01:44 PM
^^front i think its the subframe...i mean the lca mount took a hit off a curb and from eyeball view underneath it looks like the radius angle frame that comes into the lca mount is bent more then the other side...???
Old Feb 4, 2011 | 01:45 PM
BryanM.'s Avatar
Resident Gearhead
That sucks. It's a pain to remove on the ground.
At least it's not as heavy as it looks.
Old Feb 4, 2011 | 01:49 PM
NOFX's Avatar
H-T White Ops
What do you mean by body type?
It's a sedan. The chassis code is EJ8. It came stock with a D16Y8.
Generally speaking people think of a coupe as being a two door, a hatch as being a three door and a sedan as being a four door.
Old Feb 4, 2011 | 04:22 PM
thanks for the body info i was confused...
Old Feb 4, 2011 | 04:25 PM
what does it take to remove the subframe??? do you have to pull the motor or just the steering rack and suspension parts....
Old Feb 4, 2011 | 04:39 PM
NOFX's Avatar
H-T White Ops
It's cool.
I always figured people knew, but I've actually been asked the same question at my job. Nothing like asking, "Coupe or sedan?" and getting that confused look and then feeling like an ***.
Old Feb 4, 2011 | 04:45 PM
TwoFaced's Avatar
http://importnut.net/rackswap.htm
That's a decent write-up.
Get a helms manual or something too.
I just bought mine today on ebay...it was 85 shipped.
I think you can actually use the 5th gen subframe too it's just not as beefy as the 6th gen...I may be wrong.
It's also called a front crossmember if you're searching for it that might broaden your search.
I'm replacing mine next week after my shipment comes in.
Since you'll have to pull the steering rack, and I think shift linkage and whatnot...go ahead and spend about 20 shipped on steering rack bushings and shifter bushings from energy suspension. Might as well take out some rack slop and shift slop while you're down there. This is also a good time to replace tie rod ends and ball joints as well. It'd be a shame to pull apart your suspension, replace the subframe...then have something else go out you had already taken off a month or so later.
Old Feb 4, 2011 | 05:00 PM
94EG8's Avatar
Seagull Management
As far as I know you can, but you'll need a 5th gen T-bracket and LCAs as well.
Old Feb 4, 2011 | 05:06 PM
TwoFaced's Avatar
Yep...the one I ordered was for a 99 SI...there isn't any differences on those I think either.
Old Feb 4, 2011 | 06:07 PM
98civdx's Avatar
Master Detailer
I am fairly cetain, that all you need to use is the compliance bushing, and all of the hardware form the 5th gen.
Not the entire lower control arm. Although you are correct, I just thought I add that.
Bllindley
Honda Civic (2006 - 2015)
May 10, 2018 02:02 PM
s1ngle
Aug 18, 2004 07:38 PM
fixhondas
Jul 17, 2002 01:30 PM
