Haggard Gas Mileage
Old Feb 4, 2011 | 10:32 AM
91boostedSi's Avatar
Default Haggard Gas Mileage
Car's a 92 dx sedan. Up until a month ago the car was awesome on gas, now it seems like I could barely eek 140 out of a tank driving around town. Car was throwing code 1, 43, and the code for IAC valve. Replaced 02 sensor, have switched plugs out, and cleaned out the IAC valve. No code anymore, but still sloppy mileage. Also the car seems to heat up a lot quicker than my integra does. It seems like one minute into my commute and the temp gauge is already 1/3 of the way there. Any suggestions? I really don't want to put steelies on the teg and drive her in winter.
Old Feb 4, 2011 | 10:34 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Haggard Gas Mileage
Last FULL tune up? Driving habits?
Old Feb 4, 2011 | 11:08 AM
Former User's Avatar
Plug wires, cap, rotor? Ignition timing?
Old Feb 6, 2011 | 10:32 AM
I drive like a puss so it's not driving habits. Just changed out fuel filter yesterday. Seems to run better but I've drove 40 miles and the damn needle has moved from 3/4 to half already, and this was highway driving. Any chance the float in the tank could be bad?
Old Feb 6, 2011 | 10:37 AM
The Grumpiest
When was the last time you did a FULL tune up? I don't think just changing the fuel filter counts. Ron also asked about ignition timing.
Old Feb 6, 2011 | 11:45 AM
WOW !'s Avatar
lol last oil change ??
Old Feb 6, 2011 | 12:32 PM
A couple months ago when I got it put back together again.
grumble-full tune up done a couple months back when I got the car put back together. Cap and rotor was replaced then.
From what I'm starting to notice it may be something just mechanical related.
Bad injector? Valves need adjusted?
Old Feb 6, 2011 | 01:11 PM
The Grumpiest
Did you check the ignition timing?
Old Feb 6, 2011 | 07:24 PM
that's tonight. Also noticed some white smoke comming out the exhaust today. It does it upon startup-a decent amount I might add, but goes away after the car warms up. Checked the oil today and no milky residue.
miguey310
23
Jul 14, 2010 03:02 PM
preludepower
Oct 6, 2009 08:24 PM
CUTTERSPOOL
Aug 2, 2009 11:14 AM
gdm
Honda Civic (2001 - 2005)
Mar 24, 2006 11:46 AM
rajayc
Dec 10, 2005 12:00 PM
