99 si misfiring on all 4 cylinders and running rich.
ok I got a 99 si stock engine(b16a2) 156,xxx and it has short ram intake and header, now the codes it reads it shows I have misfire on all 4 cylinders, replaced spark plugs and i still have the problem and it is also running rich, ecu, or could the coil,distributor be the problem for both? i have done some research with the trusty Google but i never get a straight answer so please help me, if i am missing any info just ask, thanks
yup still runs, just ah little hesitation when i push down on the peddle, it climbs slow and hesitates while climbing on the rpm gauge.
Check your timing, I had the same problem with my civic. It wouldn't pass emissions because it was running rich changed every thing you can think of and it still failed. So I check The timing and it was was off. I fixed it and now it passed emission test with flying colors, not to mention it runs like a champ.
if your off time you will misfire like that because the spark is not sparking on (time) which you will backfire and run rich bcus your not burning fuel c0orrectly!!!!!! check that n spark plugs jus to b sure
yeah alright thanks man you don't know how grateful i am that you gave me this info, i will check it and get back to you guys, thanks everyone for the advice.
b18c99si
Aug 23, 2012 03:42 PM
gobblebox59
Feb 12, 2005 10:31 PM
