99 si misfiring on all 4 cylinders and running rich.
Old 02-03-2011, 07:52 AM
Xxcivic97xX's Avatar
Default 99 si misfiring on all 4 cylinders and running rich.
ok I got a 99 si stock engine(b16a2) 156,xxx and it has short ram intake and header, now the codes it reads it shows I have misfire on all 4 cylinders, replaced spark plugs and i still have the problem and it is also running rich, ecu, or could the coil,distributor be the problem for both? i have done some research with the trusty Google but i never get a straight answer so please help me, if i am missing any info just ask, thanks
Old 02-03-2011, 07:55 AM
Former User's Avatar
Default Re: 99 si misfiring on all 4 cylinders and running rich.
Remove the distributor cap and inspect the internals. If that looks fine, remove the coil and ICM for testing.
Old 02-03-2011, 08:09 AM
ok i will try that and see if that works, thanks.
Old 02-03-2011, 08:36 AM
EJeff8's Avatar
Yeah, a tune - up may be in order. You sure your firing order is correct?
Old 02-03-2011, 08:45 AM
TwoFaced's Avatar
^ My guess.
Old 02-03-2011, 08:50 AM
b18c8's Avatar
lmao all 4 it runs still lol make sur eu got them in order 1st
Old 02-03-2011, 10:26 AM
yup still runs, just ah little hesitation when i push down on the peddle, it climbs slow and hesitates while climbing on the rpm gauge.
Old 02-03-2011, 10:30 AM
how would i check if my ecu was firing them in order?
Old 02-03-2011, 10:40 AM
b18c8's Avatar
on time?
Old 02-03-2011, 10:45 AM
EJeff8's Avatar
Find a picture of correctly installed spark plugs and compare.
Old 02-03-2011, 06:14 PM
well my dad installed the spark plugs and he is a 20 year mechanic from McKee so i think they were put in correctly.
Old 02-03-2011, 07:11 PM
LSR 0NE's Avatar
Check your timing, I had the same problem with my civic. It wouldn't pass emissions because it was running rich changed every thing you can think of and it still failed. So I check The timing and it was was off. I fixed it and now it passed emission test with flying colors, not to mention it runs like a champ.
Old 02-04-2011, 07:36 AM
and you threw all 4 of those codes also and your car ran just like mine is doing right now?
Old 02-04-2011, 07:48 AM
b18c8's Avatar
timing im like really sure thats the prob mannn check 1st
Old 02-04-2011, 07:50 AM
b18c8's Avatar
if your off time you will misfire like that because the spark is not sparking on (time) which you will backfire and run rich bcus your not burning fuel c0orrectly!!!!!! check that n spark plugs jus to b sure
Old 02-04-2011, 09:31 AM
yeah alright thanks man you don't know how grateful i am that you gave me this info, i will check it and get back to you guys, thanks everyone for the advice.
Old 02-04-2011, 04:00 PM
b18c8's Avatar
welcome man no prob love tryin to help ppl
96 LS Turbo
16
10-31-2013 08:07 PM
b18c99si
08-23-2012 03:42 PM
danbay
01-08-2011 09:19 AM
Guineapig
04-17-2007 07:28 PM
gobblebox59
02-12-2005 10:31 PM
Quick Reply: 99 si misfiring on all 4 cylinders and running rich.
