Accord oil Leak
Old Feb 3, 2011 | 05:55 AM
F22 Accord's Avatar
Icon6 Accord oil Leak
Need help I have Accord 94 and 2 days ago I changed the oil and for some reason the oil light was flashing I check the oil and no oil was left.
The leak it’s coming from the passenger side.
Any ideas what can it be?
Old Feb 3, 2011 | 06:21 AM
Targa250R's Avatar
be professional
Default Re: Accord oil Leak
It could be a number of things. Check the oil filter itself to make sure it is sealing tight; did you make sure the gasket from the old filter wasn't stuck to the block after removal?
The oil cooler/oil filter base also has an O-ring underneath that seals it to the block. A failure of this O-ring can cause rapid loss of a large amount of oil.]
You're going to have to get underneath there and check it out for yourself.
Old Feb 3, 2011 | 06:28 AM
F22 Accord's Avatar
thanks i will check it out today.
will keep posted on the findings
Old Feb 3, 2011 | 04:11 PM
nus_dogg's Avatar
F22 engines don't have oil cooler o-ring like the H23 and H22s seeing that the OP's screen name says F22. The only thing I can think of is your Rear Main Seal is leaking since it's coming from the passenger side.
Old Feb 3, 2011 | 04:21 PM
Targa250R's Avatar
be professional
Whoops, sorry - I was thinking of an older Accord. Most F22As had oil coolers, as did the F22B Odysseys.
Old Feb 3, 2011 | 04:22 PM
nus_dogg's Avatar
Oh, I didn't know that F22A's come with oil cooler as well. Lol.
Old Feb 3, 2011 | 04:45 PM
chikin pickle's Avatar
F22A6 to be precise. The rest didn't have them.
Old Feb 4, 2011 | 07:19 AM
F22 Accord's Avatar
Icon2 Re: Accord oil Leak
How hard it’s to change the rear main seal?
Besides that what else can cause to leak?
It never leaked before all I did is an oil changed and changed the oil filter?
Old Feb 4, 2011 | 07:37 AM
JDM-LuxurySport's Avatar
Another thing i would check is the oil pressure sensor. We had it leak from there on my dads accord.
Old Feb 4, 2011 | 09:10 AM
nus_dogg's Avatar
It's hassle because you'll need to remove the transmission, clutch, and flywheel to get to the rear main seal.
You'll have to carefully remove the seal out and use a same size diameter adapter and pound the seal into it's same depth where the old one use to sit. Make sure it's flush.
Old Feb 4, 2011 | 10:01 AM
nicolaselias's Avatar
Loved
Community Favorite
Yea, I jsut changed my rear main (may as well change the front crank seal and transmission torque converter seal as your in there)..
Its a lot of my hassle and it took my mech about half days work to really get everything done... If I was going in to do that kind of work, I would just change any possible leaking seals..
Old Feb 4, 2011 | 07:40 PM
nus_dogg's Avatar
I always replaced mines whenever my new engines arrived. Not just the seals but timing belt, water pump, clutch, flywheel, etc.
Tim Martin
Feb 18, 2006 01:06 PM
92accordEX4life
Jan 17, 2006 05:30 PM
mr abstract
Aug 9, 2005 05:15 AM
I drive an IS300
Nov 14, 2004 01:30 PM
overdose
Apr 24, 2003 09:41 AM
