EG/LS Swap with random severe steering wheel shake
Old Feb 2, 2011 | 08:52 PM
Ryank327's Avatar
Default EG/LS Swap with random severe steering wheel shake
Just picked up a 92 EG hatch with a b18b1/GSR tranny swapped in. It has some kind of aftermarket engine mounts.
Now when I drive it at highway speeds it will randomly and quite often get a pretty severe shake in the steering wheel and sometimes pull to the right slightly. Its not a vibration and It's not the normal bad alignment or wheel balance shake. It feels like the whole steering column could be moving or something.
I have a feeling it might be something to do with the engine mounts but when it first happened it scared the **** outta me cause it felt like something was about to fall off the car.
Any ideas?
Old Feb 2, 2011 | 09:01 PM
beeseeries's Avatar
Default Re: EG/LS Swap with random severe steering wheel shake
Did you use new or used cv shafts with the swap?
Old Feb 2, 2011 | 09:09 PM
Ryank327's Avatar
Bought it with the swap but Im going to guess they were used.
Old Feb 6, 2011 | 08:39 AM
aaron_drifter's Avatar
i would replace the cv joints or at least check them for play at the joints. if this doesn't work let me know i will shoot more ideas your way.
Old Feb 6, 2011 | 12:17 PM
WOW !'s Avatar
i had a ef that did that **** was scarieee !! lol mine was wheel bearings just when the bearing would get hot it would act wierd might be something to check and if u dont have full after market mounts it will hav a wierd shake if u only have lik one after monut for say u only hav a trans mount thats after market u get what im saying lol
Old Feb 6, 2011 | 01:06 PM
pwebb0207's Avatar
Have you inspected any suspension components?
Old Feb 6, 2011 | 02:10 PM
Andrewhonda's Avatar
If it has power steering it could cause the vibration. You can just simply take the power steering out and it wont have too much of a diff.
Old Feb 6, 2011 | 02:15 PM
grumblemarc's Avatar
The Grumpiest
Wife's car had that. Had the tires rebalanced and replaced one of the struts since it was blown.
Old Feb 6, 2011 | 02:59 PM
Ryank327's Avatar
Raised the coilovers to max height and the problem pretty much disappeared. Then I lowered it back down about 1/2 inch and it came back so at least one of the front shocks was blown. Also makes sense cause I drove on a perfectly smooth new section of highway yesterday and it road like a dream. So I have some Koni Yellows on order already along with all new ball joints, tie rod ends and various bushings.
billybod
Jun 18, 2019 12:57 PM
HOM DON
Northern California
May 31, 2012 02:54 PM
Ryank327
Feb 3, 2011 09:39 AM
FalkenSiR
Apr 23, 2005 07:49 PM
