EG/LS Swap with random severe steering wheel shake
Just picked up a 92 EG hatch with a b18b1/GSR tranny swapped in. It has some kind of aftermarket engine mounts.
Now when I drive it at highway speeds it will randomly and quite often get a pretty severe shake in the steering wheel and sometimes pull to the right slightly. Its not a vibration and It's not the normal bad alignment or wheel balance shake. It feels like the whole steering column could be moving or something.
I have a feeling it might be something to do with the engine mounts but when it first happened it scared the **** outta me cause it felt like something was about to fall off the car.
Any ideas?
Any ideas?
Re: EG/LS Swap with random severe steering wheel shake
i would replace the cv joints or at least check them for play at the joints. if this doesn't work let me know i will shoot more ideas your way.
i had a ef that did that **** was scarieee !! lol mine was wheel bearings just when the bearing would get hot it would act wierd might be something to check and if u dont have full after market mounts it will hav a wierd shake if u only have lik one after monut for say u only hav a trans mount thats after market u get what im saying lol
If it has power steering it could cause the vibration. You can just simply take the power steering out and it wont have too much of a diff.
Raised the coilovers to max height and the problem pretty much disappeared. Then I lowered it back down about 1/2 inch and it came back so at least one of the front shocks was blown. Also makes sense cause I drove on a perfectly smooth new section of highway yesterday and it road like a dream. So I have some Koni Yellows on order already along with all new ball joints, tie rod ends and various bushings.
FalkenSiR
04-23-2005 07:49 PM
