What sensors to run OBD2 p75 on OBD1 gsr swap to pass inspection?
Trying to figure out how to wire a jumper harness in a 96 dc4 on my obd1 gsr swap. I know if I use the stock p75 i can pass inspection I just need to know what extra sensors to wire in other than the crank fluction (already using an odb2 block)..
You want to use a P72 for that motor. (Or a p28 for tuning) Don't try to get it to run on the p75, it may fire up, but you're opening a whole can of worms. Use the right ECU.
im using a p72. I only want the p75 to get me to pass obd2 inspection. i was told with a jumper and few sensor I can pass inspection with a p75 as an alternative set up ONLY for inspection. Just to clear it up Im using a complete OBD1 GSR SWAP in a 96 LS integra.................
hard_boiled_EG
Mar 28, 2009 04:13 PM
vi3tromanc3r
Jul 2, 2008 07:17 PM
MeanGreenEG9
Dec 4, 2002 11:16 PM
