All motor B18C1 setup
Hey everybody, I'm finally making some good money so time to decide what to buy for my GSR. As of right now all i have is an Iceman CAI and 2.25" ITR b-pipe with Apexi N1 muffler. These are some others items i am contemplating, let me know your opinions:
ITR cams (most likely 00-01) Should i upgrade valvetrain in case i ever get something like Skunk2 stage 2?
JDM ITR 4-1
Carsound cat
ITR pistons (not sure US or JDM)
Skunk2 Intake Manifold
Some type of Vtec controller, maybe Apexi but not sure wether i am supposed to get SAFC of VAFC (whats the difference)
OBD II to OBD I with either Spoon or Mugen program
That is all i can think of but i know there is more, I don't want something crazy, still want it to be daily driven. Also what should i limit my compression to since in So Cal we only get 91 octane? Any suggestions and advice would be GREATLY appreciated.
Basically looking for my car to get into high 13's. Will be doing simple weight reduction like CF hood, maybe lightweight rotas with sticky Azenis.
Also plan on getting some type of motor mounts, an LSD (which one is best?), lighter flywheel, and stiffer clutch.
JDM ITR 4-1
Carsound cat
maybe u should get a really good manifold. something bigger than 64 or 68mm. lsd... dang, depends how much control u want but mine is phantom and i'm happy with it so far.
OBD I and JDM header wont pass emissions either, i'll figure something out later about smog
well if u plan on staying all motor
get JDM ITR pistons instead of USDM ITR pistons (11.5:1 vs 10.8:1 CR)
hi flow cat to go w/ JDM header
better exhaust like SMSP exhaust
valve train only if ur changing redline. id recommend portflow or ferrea.
get some retainers too.
stay w/ ITR cams or Toda A's cams
cam gears
VAFC controls fuel and vtec xover. SAFC controls fuel but not vtec.
u may want to look into some standalone like hondata or AEM EMS.
and lots of dyno tuning.
cam gears
You can get Hondata's new S200 system for LESS than a V-AFC, and get a LOT more tuneability. I'm sure there are places in Cali that will tune it for you too. HondaSaver is currently having a GB on S200, so you will get a good deal. You will also have to get an OBD II->I harness but I believe that will still cost less than a Spoon/Mugen ECU, and once again full tunability = more power.
I would upgrade to Portflow outers/ITR inners (I may have those 2 mixed up). It's the valvetrain setup a lot of people are using, cheap and lets you rev high enough for most cams. Although, if you are wanting to hit 13's, you might need something more agressive than ITR's. Skunk2 stage 1's are a bit more aggressive (I have the stats somewhere) and allegedly have stock idle. If you want really wild cams, check out the "US4" setup Rocket at HondaSaver is developing. It makes more power than JUN 3's but for only $700.
HTH.
I don't think I forgot anything..
HTH.
You can get Hondata's new S200 system for LESS than a V-AFC, and get a LOT more tuneability. Although, if you are wanting to hit 13's, you might need something more agressive than ITR's. Skunk2 stage 1's are a bit more aggressive
Hmmm, any more info on this S200?
Check out all the cool features
Also yea, I'm pretty sure that I will end up getting Skunk2 Stage 2.
does a valve train consist of just valves??
I would recommend Skunk 2 Stage 1s over Stage 2s. Another member on this board known as "MPH" made 198whp in his ITR with the Stage 1s with a stock bottom end. If you build your B18C1 with ITR internals and get some Skunk 2 Stage 1s, you can pass smog and run 13s.
you are going to have to search each individual part
It comes down to what you are trying to accomplish and your budget as well as tastes
I posted my setup in your other post, that after countless hours of looking here, and talking to places on the phone.
expect to pay at least $5-6.5k after you are all done
Dom_GsR
Aug 11, 2004 10:20 AM
