Crx b16a p30 limp mode
Old Jan 29, 2011 | 11:01 PM
VTEC_2ner's Avatar
Default Crx b16a p30 limp mode
Chipped p30, Limp mode "rev limiting" at 3500 and not sure why it's doing this help would be much appreciated
Old Jan 29, 2011 | 11:18 PM
DCRB's Avatar
Default Re: Crx b16a p30 limp mode
connect the two wires at your jumper harness and count the blinks. a slow blink is ten a fast blink is one i believe. post the codes up here
Old Jan 30, 2011 | 06:11 AM
tonythetuner®'s Avatar
Did it go in to limp mode after you got it chipped?? Or was it chipped and runing fine and then go in to limp mode?? Also wat dcrb said find out wat cel codes you have
Old Jan 31, 2011 | 02:46 PM
VTEC_2ner's Avatar
At the shop they chipped it they said vtec crossed over and all and then when I went to pick it up and test drive it it revlimited at 3500. I'm thinking they gave me a messed up ecu/chip
Old Jan 31, 2011 | 05:33 PM
Yup that's wat it sounds like they messed something up most likely if it ran fine befor you took it to the shop and now it don't they messed something up go back have them fix that ****
Old Jan 31, 2011 | 06:12 PM
VTEC_2ner's Avatar
Yeah Tony they said they won't fix it unless I pay, which I already spent 500 on this...they said it's throwing a crank position sensor code...and that the wiring needs to be fixed or wires are loose from dizzy to ecu...ill check it out tomorrow...BS shop never going there again you think after spending thousands there they'd be cool with you...
Old Jan 31, 2011 | 06:25 PM
Ya check the wires by the ecu the pins should be. c1 and c2 and they are for your crank position sensor make sure they are pushed in all the way or not cut or anything and on the dizzy plug the crank position sensor wire colors will be blue/green and blue/yellow
Old Jan 31, 2011 | 08:55 PM
VTEC_2ner's Avatar
Dude Tony, the idiot forgot to plug in one of the ecu plugs all the way. Problem fixed.
but: after getting on it hard and hitting vtec(which hits hard!) CEL comes on...knock sensor maybe?
dividedas1
14
Dec 10, 2008 04:35 AM
itslogz
Jan 28, 2008 06:54 PM
mstolars
Dec 25, 2005 09:29 AM
GEO276
May 27, 2005 09:41 AM
gda777
May 4, 2005 03:49 PM
