Finally got new clutch installed, but now, speedo is going nuts.
Old Jan 29, 2011 | 09:12 PM
BeantownBeatdow's Avatar
Default Finally got new clutch installed, but now, speedo is going nuts.
Well the good news is, I have a new clutch, and my tranny now shifts like butter again. The bad news is, my speedometer is out of control, and bounces around like crazy. Also, my trip meter isn't accurate. Today, I took a drive that was probably around 5 miles, and the trip meter read 15.
I'm not super worried, because I've seen this happen before, and it obviously is related to the recent clutch change, but I'm not sure exactly what/where to check. Vehicle Speed Sensor? What exactly am I looking for?
Old Jan 29, 2011 | 10:04 PM
dc2LS's Avatar
Default Re: Finally got new clutch installed, but now, speedo is going nuts.
sounds like your vehicle speed sensor isnt plugged in all the way.Make sure you hear it click when you plug it
Old Jan 29, 2011 | 10:13 PM
mouab18c1's Avatar
Check your VSS plug. Sounds like it has corrosion. Mine did the same thing.
Old Jan 29, 2011 | 10:41 PM
I will do this.. is there a good diagram out there that shows me where this is?
Old Jan 29, 2011 | 10:49 PM
mouab18c1's Avatar
Wait this is a hydro transmission correct?
Old Jan 29, 2011 | 11:07 PM
Yup
Old Jan 30, 2011 | 08:39 AM
mouab18c1's Avatar
Then check the connector for the VSS. You should be able to see it connected to your speed sensor. Just unplug it and look for corrosion inside of it.
Old Jan 30, 2011 | 10:49 AM
Can you get to it from top, or do you have to go under the car..?
Old Jan 30, 2011 | 11:35 AM
mouab18c1's Avatar
Do you not know what the Vss look like? It is accessed from the top.
Old Jan 30, 2011 | 12:54 PM
No, I don't obviously hence the questions. Thanks.
Old Jan 30, 2011 | 02:30 PM
mouab18c1's Avatar
So apparently you had someone do the work for you?
Take it back to them and have them look at it then.
Old Jan 30, 2011 | 02:56 PM
Yeah, I didn't do the work myself....
But It was easier than I thought, which is why I was confused. It was that connector.. Was just a tad lose. Very surprised it was that simple.. I took it for a 10 minute drive and the speedo worked perfectly, and it was messing up almost all the time before, So I think we're good.
Thanks for the help, mouab18c1. It was almost too simple!
Old Jan 30, 2011 | 03:48 PM
mouab18c1's Avatar
Glad you figured it out and you're welcome.
Old Feb 1, 2011 | 12:22 PM
Edit: Problem not fixed. Seems to be OK when I first drive the car, and as long as I take it real easy.. Could also be coincidence, but it seems like it starts going nuts when I accelerate harder.. I'm gonna mess around with it this afternoon.
Old Feb 1, 2011 | 01:11 PM
csmith21's Avatar
Probably because it isn't making a snug connection somewhere.
Old Feb 1, 2011 | 02:03 PM
mouab18c1's Avatar
Check for corrosion on the plug.
Old Feb 1, 2011 | 07:27 PM
OK so I THINK I've figured it out this time. Checked the VSS connector and it looked fine.. But I just removed my intake and grabbed the connector, and it wasn't even connected. They were together, but like someone mentioned, they weren't snapped together.
That plastic part that actually snaps the two pieces together isn't functioning properly.. But that's a pretty minor deal. I was finally able to snap it on and it felt real snug. Took it for about a 15 minute drive, and it was fine.. Every other time, it has messed up well before 15 minutes. Would be shocked if that wasn't the problem.
Anyways, thank you all for you input. Wouldn't have been able to zero in on the VSS connector without you guys.
Old Feb 2, 2011 | 05:57 AM
TheAsian's Avatar
Check the wiring at the connector, I've seen quite a few where they corroded and will get erratic signal. Corroded wire looks greenish if that's the case splice in a new connector.
Another thing you can do is actually pull the sensor out and see if there is build up on the sensor itself. That is rare but has caused problems to.
Old Feb 2, 2011 | 07:56 AM
mouab18c1's Avatar
Did you read the OP's last post?
Old Feb 2, 2011 | 02:26 PM
94VTEC2TONE's Avatar
nice job man. and ya sometimes the part brakes or its just an oversite when someone puts it back. good thing you fixed it man
Hondaindy209
Honda Accord (2013 - 2015)
Jul 17, 2019 07:48 AM
jonnyshatter
Jul 4, 2013 11:02 PM
bg-33p
Feb 12, 2005 10:33 PM
preludebabygrl
Jun 4, 2003 05:34 AM
dropd4door
May 31, 2003 06:39 AM
