heater problem
Old Jan 29, 2011 | 05:31 PM
97njsilverhatch's Avatar
Default heater problem
blower motor crapped the bed on me this past week, went and baught new one. plugged it in tested it and it worked. put kick panel back on and went to go to work the next morning and it doesnt work. checked fuses in car and they are fine. then i thaught it might have been a power transistor. so i put a new one in and it still doesnt work. any other ideas on what it could be?
Old Jan 29, 2011 | 05:34 PM
Former User's Avatar
Default Re: heater problem
Does voltage reach the blower plug?
Old Jan 29, 2011 | 05:37 PM
i put a tester on it and it was not showing any power. what else could it be?
Old Jan 29, 2011 | 05:41 PM
Double check 40A hood fuse 55 and 7.5A dash fuse 17. Use your test light to check for voltage on both sides of each fuse.
Old Jan 29, 2011 | 05:43 PM
i never checked the one under the hood. i will check in a.m thank you very much. if that comes back ok is there anything else to check?
Old Jan 29, 2011 | 05:44 PM
Double check both fuses and post the results. Then we'll go from there.
Old Jan 29, 2011 | 06:08 PM
i just checked the 40 under hood and its blown... thank you very much!!!
UniqueX707
Oct 24, 2011 10:21 AM
jdm0ua
Audio / Security / Video
Nov 18, 2007 05:31 PM
H.
Aug 24, 2006 10:19 PM
nerd28
Jul 16, 2006 05:36 PM
BlackGSR87
Mar 8, 2003 07:34 AM
