jdm d15b dont know if i have the right ecu or right head since it doesnt say vtec
Old Jan 28, 2011 | 08:57 PM
92civichatchvx's Avatar
Default jdm d15b dont know if i have the right ecu or right head since it doesnt say vtec
Just need a little advice I'm sure there's a post on here for the same question but I have a 1992 Honda civic hatchback VX model it has a d15b and I think I have a p07 ecu and reading online I need a p08 ecu its single vtec online one solenoid is there so I'm not sure if.I have a vtec e motor in it so any advice is appreciated oh the head on my motor does not say vtec thanks again
Sorry use to other forums not this one
Old Jan 28, 2011 | 11:08 PM
Alpha_Omega's Avatar
Default Re: jdm d15b dont know if i have the right ecu or right head since it doesnt say vtec
You need a p28 ecu which is the vtec one to work perfectly.
However you can use a p06 one if you chip and tune it. Anything else will NOT work
Old Jan 28, 2011 | 11:09 PM
EDIT: didn't even see that it doesn't read VTEC my bad dude!!!
Old Jan 29, 2011 | 05:05 AM
Yea the head doesn't say vtec but I see the solenoid so yea idk its weird what can u do to get more power since it is a true d15b cuz I've been looking it up and all will cams do anything for me or is it just a waste of time and money?
Old Jan 29, 2011 | 05:07 AM
Icon2 Re: jdm d15b dont know if i have the right ecu or right head since it doesnt say vtec
Sorry for the double posts I think i have a p28 I'm going to check today and should i be able to hear my vtec crossover because I don't so what can I do to know if vtec is going into effect ill post pics also of the head engine stamp and the solenoid
Old Jan 29, 2011 | 05:19 AM
HAMOTORSPORTS's Avatar
1992 and 1993 D series VTEC engines don't read VTEC on the valve cover.
If it is a true D15B JDM Vtec engine, then the ideal ECU would be a P08 or a chipped P28 with the correct basemap for the D15B.
The P07 is the original ECU for the VX engine.
Old Jan 29, 2011 | 06:18 AM
Ok well where the cam is it looks like a jdm one with ngk on it and Japanese writing the motor was swapped before I got the car and the stamp only says d15b I'm going to get pics of everything after work so it may help yall
Old Jan 29, 2011 | 06:20 AM
foo fighters's Avatar
D15Z1 is not V-tec as we know it. It only changes from a 12 Valve mode to a 16 Valve mode. NO V-tec ecu(P28/P08/p2p) will run it, ONLY the P07 can run the D15Z1......BUT one guy on here posted a thread on how to change the D15Z1,P07 head into a D16Z6/P08 head.
Old Jan 29, 2011 | 06:28 AM
Ok but I have the vtec solenoid and all and the stamp only says d15b that's it
Old Jan 29, 2011 | 02:38 PM
Ok so i have a p07 so all I need to do is swap that with a p08 and it should be good Togo right?
Old Jan 29, 2011 | 06:20 PM
ej1916's Avatar
Yes if you swap to a P08 ECU, which is the JDM ECU for the JDM D15B then it should work fine. Or like others stated, you can use the P28 ECU. I think you would have better luck finding a P28 ECU. I have a D15B and I'm running it on a P28.
Old Jan 29, 2011 | 08:20 PM
Ok thanks for the help
Old Jan 29, 2011 | 11:27 PM
virgineg6's Avatar
wont run the engine or the lean-burn the z1 is famous for? Cuz im running a d15z1 with a p28 as we speak runs hella good to! just had to wire in the 4 wire o2 sensor cuz that wide band o2 is to expensive.
Joshua_Missey
Honda Civic (2001 - 2005)
Jun 28, 2018 12:35 PM
vtechaccord
Mar 14, 2011 03:03 PM
95JDM
Jul 16, 2008 06:47 PM
bigsubs
Jun 15, 2007 08:42 PM
JDMB20TDA
Mar 18, 2007 11:13 PM
