camber kit?
I just purchased skunk2 pro series coilovers and shocks for my teggy, but when I slammed it the front the wheels pop out do i need a camber kit?? if so which one do you guys recommend???
btw: I got an alignment and the front wheels was still popping out.
Yes you need a camber kit. But it won't make much a diffrence yes the tire will sit vertical. But camber does not wear tires toe does. get a alignment you should be fine. Only time camber effects tires is when you have excessive amounts of negative camber
I have the same coilovers and had the same problem. I got the skunk 2 upper control arms, but i dont think they are any better than the blox or k-sport. A couple times i had to tighten the allen screws that hold the adjustable plate cause they came loose.
pr0phet
Nov 22, 2005 03:59 PM
