camber kit?
Old Jan 28, 2011 | 07:21 PM
manchildteggy's Avatar
Default camber kit?
I just purchased skunk2 pro series coilovers and shocks for my teggy, but when I slammed it the front the wheels pop out do i need a camber kit?? if so which one do you guys recommend???
btw: I got an alignment and the front wheels was still popping out.
Old Jan 28, 2011 | 07:28 PM
ElementzofR's Avatar
Default Re: camber kit?
yes you definitely need a camber kit. get the matching skunk2 pro series front camber kit.
Old Jan 28, 2011 | 07:39 PM
tonythetuner®'s Avatar
Something is rong if the tire is poping out word. if any thing they should tilt in not out...
Old Jan 28, 2011 | 07:53 PM
lol thats what i mean tilt in.
Old Jan 28, 2011 | 07:55 PM
Ok i guess i need a camber kit, but is their any other name brands besides skunk 2?
Old Jan 28, 2011 | 08:07 PM
Yes you need a camber kit. But it won't make much a diffrence yes the tire will sit vertical. But camber does not wear tires toe does. get a alignment you should be fine. Only time camber effects tires is when you have excessive amounts of negative camber
Old Jan 28, 2011 | 08:19 PM
thanks bro!
Old Jan 28, 2011 | 08:25 PM
theres k-sport and blox too.
Old Jan 29, 2011 | 08:43 AM
94 ls-r's Avatar
I got the pro series on my teg for a few years and it been great. Its not that low so for the rear I just used spacers and longer grade8 bolts.
Old Jan 29, 2011 | 09:31 AM
mattyfo0z's Avatar
I've had friends buy the no-name brand eBay camber kits, and they've worked fine.
Old Feb 1, 2011 | 02:42 PM
csirdc2's Avatar
10 Year Member
A lot of my buddies have the skunk2 front Camber kit and it works good... just be aware that if u slam it a lot of places won't want to do the alignment... well Atleast that was my problem?!
Old Feb 1, 2011 | 02:52 PM
91integra_rubio's Avatar
I have the same coilovers and had the same problem. I got the skunk 2 upper control arms, but i dont think they are any better than the blox or k-sport. A couple times i had to tighten the allen screws that hold the adjustable plate cause they came loose.
Old Feb 1, 2011 | 02:56 PM
94VTEC2TONE's Avatar
i just ordered the skunk2 camber kit, im definetely going to be using blue threadlocker after heraing there plates come loose
FLACO EM1
Nov 27, 2008 01:39 PM
95_red_dc
Suspension & Brakes
Oct 13, 2008 11:29 AM
crx1009
Apr 5, 2006 09:57 AM
pr0phet
Nov 22, 2005 03:59 PM
tr4il
Nov 23, 2001 10:14 AM
