my d15b vtec civic burning excessive fuel
Old Jan 28, 2011 | 05:20 PM
Organization's Avatar
Default my d15b vtec civic burning excessive fuel
not sure if this is the right forum to place this in but i was looking for a lil help in finding out why it is burning more fuel after a rebuilt heads replacement
i got it from another guy that swaped in a d15 j-spec and p-28 ecu well it ran fine till the headgasket started leaking, well i took the head off got it rebuilt and slaped it back on with a new hg kit and water pump,new oil + filter radiator fluid, t-stat, spark plugs, cap and rotor
imma change out the injectors 2mmorow but would like some insight on what it could be
Old Jan 28, 2011 | 08:48 PM
Former User's Avatar
Default Re: my d15b vtec civic burning excessive fuel
Did you also replace the plug wires? Have you checked the mechanical and ignition timings? Any CEL codes?
Old Jan 28, 2011 | 11:11 PM
yes i changed the wires theres no check engine light and i assumed its on time since i put it back together per the haynes manual but imma get a timing light tommorow and do another compression test
but other than the bad mpg's it runs fine
o sorry it seems the exhaust got louder like a blown muffler so imma check the o2 sensor cat and muffler
Old Jan 29, 2011 | 06:34 AM
Does the CEL work?
Old Jan 29, 2011 | 07:15 AM
jmeyer99's Avatar
Do a compression test on each cylinder.
Old Jan 29, 2011 | 07:51 AM
viciousvisionslarry's Avatar
you probably wiped out ur o2 sensor when the head gasket blew.
hatchizzle
Feb 23, 2013 07:09 PM
h3rsh3y2001
Apr 4, 2009 11:36 AM
8083tcman
Jan 29, 2009 04:58 PM
OhWUNshlude
Nov 29, 2007 09:37 PM
fitbmx86
May 20, 2007 04:59 PM
