Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch master cylinder/slave cylinder question..
Old Jan 28, 2011 | 01:14 PM
graveltravel2's Avatar
Default clutch master cylinder/slave cylinder question..
ofcourse we have done motor swaps in here....
but, is there actually a difference between a d-series and a b-series clutch master/slave cylinder??
i have a hype r swap in my ej1, but i reused my d16z6 clutch slave cylinder and master cylinder...
i just wonder if the b-series counterparts are more heavy duty/puts out more pressure...
Old Jan 29, 2011 | 03:25 PM
Default Re: clutch master cylinder/slave cylinder question..
ttt
Old Jan 30, 2011 | 08:00 AM
daluv's Avatar
no, they are the same.
Old Jan 30, 2011 | 12:33 PM
thanks!
Old Mar 13, 2011 | 08:43 PM
JDM_addict's Avatar
guys, maybe some of u can help, how do u know a clutch master pump is alrdy bad?
Old Mar 14, 2011 | 05:42 AM
94EG8's Avatar
Seagull Management
You should really start a new thread, but generally they'll start leaking brake fluid out the back where the pushrod goes into the master cylinder (you'll see brake fluid running down the inside of the firewall under the dash)
Old Mar 14, 2011 | 06:28 AM
JDM_addict's Avatar
sorry about that, suddenly i came accross this thread n it will be a good idea to ask here.
but my master cylinder was already off the wall, there was abit rust on the inner of whre the pushrod connect to the piston on the mc
94accord718
Oct 5, 2007 01:28 PM
solomon_edward
Dec 9, 2005 02:03 PM
lo0nY
12
Jan 28, 2004 02:15 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
