z6 in EK: issues with fuel pump/first start
Hey guys,
I have quite the problem here, so I just swapped my turbo z6 out of my EG into my EK (99 EX Sedan), have all the hardware hooked up and I left my obd2 alternator connected, got a conversion harness for the dizzy and the ECU. I left the CKP and knock sensor plugs disconnected and put the IAT sensor in my charge pipe and hooked it up. I have a resistor box, DSM 450 injectors, using the y8 intake manifold.
So I go to start it yesterday and the fuel pump keeps running after the 2 second prime. The check engine light very briefly flashes and goes off immediately, the ABS computer seems to start up just fine.
I noticed that the starter Solenoid got SUPER hot, I didn’t try cranking it, figured it’s too messed up at this point.
So I have disconnected the resistor box and checked the ohmage across the red wire and all 4 black wires to be 5.6 ohms which is within spec.
I put hooked the obd2b ECU back up and it does the exact same thing, uplugged the dizzy harness and does the same thing.
I checked the t-stat ground and engine grounds, any ideas? Im thinking maybe the main relay? What would cause the starter SOLENOID to get glowing hot?
Thanks for anything!
James
James
scooterbuilteh2
Oct 25, 2009 02:08 PM
