GSR into EG swap. Issues with linkage.
i am doing a gsr swap in a eg civic... motor is in and with a gsr linkage bought i try to align it and if i connect the tranny the two bolts that go to the body , next to the shifter looks to be about 2" too small. are ther differnet lenght shift linkages for b-series tranies?
any help will be greatly appreciated.
thanks,
thanks,
I fixed the title.
From the ToS https://honda-tech.com/forums/general-discussion-debate-40/site-guidelines-2599445/
Please keep that in mind the next time you're making a thread.
When starting a topic, make the title specific enough that people scanning the list of forum topics will know what's inside. "Need help" or "have a question" are not specific enough. If you want someone to open your topic, give people an idea what it's about.
thanks,
thanks,
Del Sol linkages are actually longer '90 - '93 Integra are very slightly shorter than '94 - '01. I'm guessing it's an '88 - '91 Civic/CR-X B-series linkage, IIRC they're shorter.
The del sol linkage is actually bent to go up into the shifter area of the del sol (due to the chassis design of the del sol), so it will not work at all. '90 to '93 integra are actually exactly the same as '94 to '01, except for the fact that they have the narrower base single bend shifter like a d series linkage would.
92civichatch1
Mar 8, 2006 08:54 AM
Eg_TypeR
Jul 27, 2005 09:09 PM
length
Mar 22, 2003 01:57 PM
Lookincrazy
Apr 18, 2002 11:55 PM
