Radius rods, full race guys are you running them?
I think it has to do with the size of the slicks they run. Plus, who needs that when you have wheelie bars in the rear.
[Modified by Prelude_RCR, 8:05 PM 9/24/2002]
I would think you can acheive more + caster with out them. Cause with out them when you launch your wheels automatically pull as far forward as they can by wheel and tires trying to drag the rest of the vehicle. I see what you are saying that you can set your caster super tight, but I would guess running no radius rods would give you greater caster less drive train shock and less immediate wheel spin. Don't know if all this holds true but it makes sence to me. If you have info or experiences that disprove this please post.
Running the radius rods helps to control wheel hop and can also pull more positive castor in which helps keep the weight on the front wheels during acceleration.
http://www.jimfab.com makes great bars for the crx. Other models coming
You're talking about changes in wheelbase, not caster.
I know swaping the upper control arms from left to right will give you more caster. Will this help reduce wheel hop at all?
eXcelonTypeR
Jul 16, 2005 05:32 PM
