oil pressure light flashing!
Old Jan 27, 2011 | 12:06 PM
kseriesdreams's Avatar
Default oil pressure light flashing!
so i was scootin along one day. and my oil pressure lights starts to flash. then stops for awhile. then does it again. now it does it all the time. so i replace the sensor thinking that would help. Nope still does it. is it just a problem with the wiring or something more serious?
Old Jan 27, 2011 | 12:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: oil pressure light flashing!
Oil pump failing?
Old Jan 27, 2011 | 12:12 PM
EJeff8's Avatar
Actually low on oil?
Old Jan 27, 2011 | 12:26 PM
Former User's Avatar
Stop driving the car now and hope the engine is not already destroyed.
Old Jan 27, 2011 | 12:58 PM
andyz's Avatar
oil sump screen clogged?
Old Jan 27, 2011 | 01:42 PM
The Grumpiest
Probably driving it right now.
Old Jan 27, 2011 | 02:18 PM
94EG8's Avatar
Seagull Management
Probably standing on the side of the road beside it right now.
Actually I know guys, myself included that had D-series engines that burned enough oil that you'd get to a point where the oil light would come on going around turns, stop, add more oil keep driving, never spun any bearings either. Not that i'd recommend it. In my case I was running a D15B7 that was burning 3 - 4L a day so I really didn't care if it blew up.
Old Jan 28, 2011 | 05:34 AM
EJeff8's Avatar
Haha, that's my friend's Del Sol. We call it the Fumeador. If you **** him off, your car gets a grill full of oil - laden exhaust. Also kills Mosquitos, very effective.
Old Jan 28, 2011 | 06:16 AM
derger207's Avatar
Icon3 Re: oil pressure light flashing!
this is your best bet. if your oil light is flashing it means your oil pressure sending unit isnt seeing AT LEAST 4 pounds of pressure which is BAD. basically your top end is running dry and your valvetrain hates you. check your oil first, then pull your valve cover and see how bad it is under there, if its still good id replace your oil pump AND your pickup screen
Old Jan 28, 2011 | 07:29 AM
andyz's Avatar
How much is an oil pump?
Old Jan 28, 2011 | 08:02 AM
Jockone's Avatar
Take out the oil pressure sensor and use an oil pressure gauge to check your oil pressure so you know for sure but it does sound like an oil pump failing or a clogged pick-up screen.
Old Jan 28, 2011 | 08:13 AM
Jimster480's Avatar
It sounds like your oil pump is failing. Change it ASAP. because less than 4 PSI oil pressure = very bad.
Old Jan 28, 2011 | 11:14 AM
apexi_rsx's Avatar
the top end is hating you more like ur rod bearings are hatting you as well. it sounds like hes already drove it enough to cause enough damage.
Old Jan 28, 2011 | 11:39 AM
derger207's Avatar
Ya true his whole engine probly hates him and yes under 4 psi is really bad but for some reason that's when the sending unit flips the light on lol but ya check your pressure just to be sure. Give me the year make and model and I'll get you a price, I work at advance auto so I'll jus check for you at work tonight
Old Jan 28, 2011 | 09:38 PM
EJeff8's Avatar
Ha, no offense, but if he wants to do it right and make sure this won't happen again, he'll go to Honda.
Old Jan 28, 2011 | 10:32 PM
raverx3m's Avatar
kids in africa probably hate him as well for wasting oil.
if your pickup screen is clogged that probably means your bearings are in there and not where they supposed to be( on the crank and rods)
heres how it goes.
your engine get low on oil or overheats> your bearings wear off and **** out all that shiny surface into the crankcase/oil pan> they get stuck in the puckup screen and clog it eventually> your oil pump gets some of that bearing dust and ***** out its gears. and so on.
Old Jan 29, 2011 | 06:05 AM
James_Starks's Avatar
check the pressure with a gauge just so you know for sure what it has. on a different car i had the oil light was alwas flickering it pissed me off. I check the pressure and it was fine. Found out that the connection was bad causing it to flicker. Check the pressure before you drive it anymore
Old Jan 29, 2011 | 08:22 AM
derger207's Avatar
Hahaha none taken I don't blame you lol kus figured if it's his daily that's already trashed it's not worth dumpin the money into it lol
Old Jan 29, 2011 | 08:28 AM
derger207's Avatar
heres how it goes.
Hahahahahaha
Old Jan 30, 2011 | 02:55 PM
car blew up daaamn goodbye b16
Old Jan 30, 2011 | 02:56 PM
The Grumpiest
Big surprise.
Old Jan 30, 2011 | 04:28 PM
andyz's Avatar
At least you saved yourself $145 for a new oil pump.
Old Jan 30, 2011 | 04:31 PM
andyz's Avatar
http://shop.advanceautoparts.com/web..._1366873576___
MyUsernameName
Jun 15, 2017 02:06 PM
Schultzie
Jul 10, 2010 08:58 PM
lonewsome
Jan 1, 2009 01:42 PM
xlee08
10
Apr 1, 2008 02:00 PM
FastAzzDA
Oct 20, 2006 03:07 PM
