No compression when downshifting
Hi, im new on here and i dont know if i posted at the right place so sorry I bought a 95 civic DX but the motor is a 2000 D16Y7. I ran a compression test and got about 185-190 on all 4 cylinder! My question is : When downshifting i dont feel the compression like it should but my test was 190 on all 4 so could it be that my test was wrong or could it be something else! You know the feeling when you downshift and you feel the car really slowing down? It almost doesnt do it except for third to second gear!
Re: No compression when downshifting
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Sorry for the title thanks for fixing it! And yes while doing the test i had the gas wide open!! I have a check engine that just appeared so i will jump the connector and get the code!
I just went to park my civic behind my block and the CEL is gones O.o it appeared earlier when i floored it and now looks like it disappeared!! Weird!! So i guess i need to find how to set my idle to spec !
Are any CEL codes thrown?
Any CEL codes? If so, post them.
Also check whether the throttle cable is adjusted too tightly. It should have about 1/2" of free play. Also check whether the throttle body is dirty, which can cause the throttle plate to become stuck partially open.
No CEL. And i will go and check the throttle body and throttle cable tomorrow its hard at night haha + winter sucks for car repair when you dont have a garage and i dont have a garage
crapanese
10-30-2006 10:25 AM
