Oil Light turns on
Oil Light turns on
someone shed some light for me.
My engine oil light turns on if the engine is under 1k rpm. When i accelerate, or go then it goes away. If i come to a stop, then it turns or flickers back on. I just got an oil change and there is oil in the engine.
Has anyone ever had this before?
Re: Oil Light turns on (z6hatchboy)
i just did an oil change 3 days ago. This came up before that. I thought the oil change might fix it. Filter is tight.
Re: Oil Light turns on (xlee08)
the cause of the low pressure is either a bad pump, 99% of the time, or tolerances within the motor are worn too big. as long as the motor isnt knocking or making nay odd sounds put a pump in it
yeah its the oil pressure. when your car idles the oil pressure flexuates. bad oil pump? get it fixed asap. your internals might not be getting enough lubricant.
3 things Oil level, Oil Pressure, oil pressure sensor easiest thing to do is look for leaks check filter tightness or take it back to where you had your oil changed they might have 2 gaskets on the mounting plate or a bad gasket on the filter, check oil level, then if the light doesn't go out oil pressure sensor. Hope it helps!
