obd1 gsr swap
Old Jan 27, 2011 | 06:18 AM
HarosGSRek's Avatar
Default obd1 gsr swap
so I have the swap done. Cars running ok. It's a 98 civic (obd 2).
the setup is pretty much a obd1 gsr motor with a obd2 distributor & alternator. I also have a type r replica intake manifold.
I'm using the factory obd2 wiring harness that was on the d16y7. And I switched the ecu for a p28 using a obd2 to obd1 jumper harness.
my question is.. Is there a write out of everything that needs to be done to the harness for it to work properly. Or a diagram that has ever plug on that harness
labeled to where it goes on my setup?
I've been searchin and I'll continue to search, but if anyone can help me out that'd be great.
thanks
Old Jan 27, 2011 | 06:23 AM
REDEM1FTW's Avatar
Default Re: obd1 gsr swap
Browse through the "Ecu and Wiring" section of ---> http://ff-squad.com/technet/
Tons of useful ecu pinouts and wiring diagrams, hope this helps man
- Josh
Old Jan 27, 2011 | 06:36 AM
HarosGSRek's Avatar
thanks
Old Jan 27, 2011 | 08:26 AM
REDEM1FTW's Avatar
Np man post back and let us know how it comes out
Old Jan 27, 2011 | 10:20 AM
HondaPartsHero's Avatar
Technical Hero
Should be a piece of cake. You'll only need to wire the VTEC solenoid and pressure switch. Also you'll need to wire up a 2 wire IACV to convert from a 3 wire. Also you'll need to use a different IAT and connector or place your Y7 IAT into your intake arm. You're also going to need to extend your primary 02.
Rok_Stok
Oct 22, 2010 03:04 PM
JustAskMe
Aug 19, 2010 10:47 AM
trevek10
Sep 18, 2009 06:43 AM
ELIT3
Aug 6, 2009 02:55 PM
DGAF
Jul 7, 2005 05:37 AM
