Alternator Replacement, 99 si
Old Jan 27, 2011 | 05:41 AM
TnC's Avatar
TnC
From: Sin City to CA, to TX, NC to FL, then back to NC...
Default Alternator Replacement, 99 si
Concerns about replacing my alternator... I have no PS or AC... So, to replace my alternator, do I just loosen the two bolts holding the alternator and replace it? And what alternator would be the best bang for buck? I was looking into NAPA for their alternators. Thanks!
Old Jan 27, 2011 | 06:13 AM
D Griff's Avatar
Default Re: Alternator Replacement, 99 si
I just got an Autozone one about a year and a half ago and it's been fine so far. It's easy to replace. Remove the wires, loosen the bolt that it pivots on and remove the belt. Then remove the pivot bolt and remove the alternator. The toughest part is getting it to fit out of there, I think I had to drag it out from the bottom. I think you may have to remove the bracket it's mounted on as well for it to fit out of the car, but I don' remember this for a fact.
Old Jan 27, 2011 | 06:26 AM
TnC's Avatar
TnC
thanks for the advice, can anyone else confirm this? any pics to with it?
Old Jan 27, 2011 | 06:34 AM
Jockone's Avatar
I have used Napa and Advance autoparts alternators with no problems.
Replacement is easy as Dgriff said but you do have to remove the bracket to get the alternator out.
Undo top bolt,loosen the pivot bolt(easiest from underneath),disconnect wires and remove belt.Remove not from pivot bolt and push bolt out,move alternator to rear crossmember or somewhere out of the way and undo and remove bracket.Take alt out and replace with new one and reverse what you did job done.
Old Jan 27, 2011 | 06:45 AM
TnC's Avatar
TnC
perfect, thanks guys
Old Jan 27, 2011 | 08:21 AM
b1u3_5i's Avatar
Also, disconnect battery before you begin. Lesson learned.
Old Jan 27, 2011 | 08:32 AM
Former User's Avatar
Yep, disconnect the battery and remove the lower mount bracket.
Old Jan 27, 2011 | 10:11 AM
fasterthanueg's Avatar
Your best bang for your buck is my brand new alt for 50.00. I ordered it and got an obd2 one instead of obd1. Pm me if you want pics this alt has never had a belt on it.
Old Jan 27, 2011 | 12:13 PM
TnC's Avatar
TnC
update.... found the culprit of it's squeaky madness. found out it wasn't the alternator, but the lower bolt that goes through the alternator and bracket was missing. there was definately a little bit of play in the alternator as well. called the dealership and scored on the bolt. as for the nut, i would have to wait on special order that will come in by tomorrow. problem is, i need it asap! would any 10mm nut work? any specific grade i would need and such?
Dave_Dc2
Sep 12, 2010 10:20 PM
--eclipse--
Jun 18, 2007 08:55 PM
Synthead
Jul 31, 2005 08:55 PM
ch4nq
18
Jul 26, 2004 01:59 AM
keithv
Aug 15, 2003 01:11 PM
