Stupid... But Si Cluster Question.
Old Jan 26, 2011 | 11:36 PM
AlphaKennyBody's Avatar
Icon2 Stupid... But Si Cluster Question.
I have a 99 EK DX and picked up on a SI cluster.... All works well but for some reason, I can't find the High Beam Indicator on the Cluster.... I KNOW I KNOW hella random question but where is it located....
Now before I get some smart *** reply like "Turn on your High beams Noob!!!"
Been there done that... High Beams work fine but it doesn't say it on the Cluster if I have them on or not.
I tried searching and looking on google but couldn't find an answer... Thanks in advance.
Old Jan 27, 2011 | 02:52 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Stupid... But Si Cluster Question.
It should be a blue-ish lens on the surface of the cluster. Shine a flashlight onto the cluster and you should be able to see it.
It's one of the ones between the Rev counter and the speedo.
I want to say it's the one to the top right of the turn indicator light.
Or you could pull the cluster, inspect which bulbs are out, and just replace that one.
Edit: Just realized I used British terminology there. Too much top gear
Old Jan 27, 2011 | 02:55 AM
JasonYo's Avatar
The bulb is probably burnt out or missing, just take one from somewhere else in the cluster temporarily to check.
Old Jan 27, 2011 | 03:22 AM
habib's Avatar
If its burnt out just take a bulb from your old cluster
Old Jan 27, 2011 | 08:49 AM
Red_Army's Avatar
^^that.
at least its the british top gear and not the red headed step child that is historys TG.
Old Jan 27, 2011 | 08:56 AM
Mrevann's Avatar
GDD Black Reject
if u pull the cluster out .. just replace all the bulbs so u wont have to do it all over again ... just saying
lkwdscr7
Mar 19, 2009 03:51 PM
jdmcivicracer89
May 31, 2008 10:23 AM
BoostedH
May 26, 2008 12:35 PM
bigBOI_92DA9
May 30, 2004 03:09 PM
Caveman74
Apr 3, 2003 04:56 PM
