b16a sir1 final part list check
I'm about to swap a b16a sir1 into my 92 civic hb vx. This is my part list i been researchin for days some of the things I'm still questioning and if I left anything out or added something not needed let me know my first b series swap I want it to go smoothly lol. With less headache and don't smoke my self self to death. Jk
Motor/tranny: first gen b16a with cable tranny
Hasport cable conversion kit
Mounts&harness haven't found I should use. Don't want to buy new mounts to expensive.
Driverside/rear brakets from 94-01 teg/depending on 2-3 bolt driverside
Obd1 izzy
P28 chipped ecu-bypass knock sensor
obd1 headers?
Type R throttle cable
Axles from 94-01 teg
Shift linkage from 94-01 teg
Type R half shaft? <-- STILL don't know wtf this is!! :/
Si coolant hoses
Use injectors from my busted D15Z1
Wiring: mild wirin for fan,convert to 4 wire narrowband o2
Ofc antifreeze oil filter other fluids spark plugs wires.
Please let me know what u think. Will I run into problems and if u can answer those ? About mounts and harness and half shaft tht be awesome
Obd1 izzy
obd1 headers?
Si coolant hoses
Re: b16a sir1 final part list check
didn't your engine come with the mounts on them? ebay them and they won't be expensive. use your old harness and extend some wires possibly wire in vtec too. or you can buy a new one from rywire but thats money you don't have.
halfshaft- its the longer of the two axles. coulda googled that but your welcome for being spoon fed.
ps this is one of the MOST expensive hobbies to do right. also why'd you get an old first gen?
