are all obd1 injectors the same?
Old Jan 26, 2011 | 04:58 PM
black0hatch's Avatar
Default are all obd1 injectors the same?
i running obd1 injectors in my crx and usually you dont run the resistor box with them. but on these injectors they need the resistor box to run. i never had that happen before. i thought maybe there off a vx or something or maybe not even from a civic?
Old Jan 26, 2011 | 06:03 PM
Nickeg9Ej1's Avatar
Default Re: are all obd1 injectors the same?
Prelude or accord inj use a resistor box. If they r h22 inj they r larger. I think they are 310cc.
Old Jan 27, 2011 | 05:26 PM
ya i cant really say what there off of. i bought the complete inake and it had the wrong injector o rings at the bottom so i think theyve been changed out at one point. do the bigger ones look the same as d series? these ones look exactly like all my other injectors.
Old Jan 27, 2011 | 06:12 PM
Nickeg9Ej1's Avatar
They look that same as d series but will just cause you to run rich if they are 310cc on a stock ecu
Old Jan 28, 2011 | 05:27 PM
ok thanks. i got spares i can swap out if i need to. i just thought it was weird it needed the resistor box.
Rawrlos
Sep 24, 2013 04:59 AM
raidacaipo
Feb 15, 2009 01:33 AM
immorality
May 24, 2008 03:46 PM
killa rex
Jan 25, 2006 02:54 AM
