code 10 rough running help
Old Jan 25, 2011 | 06:30 PM
b93hatch18's Avatar
Default code 10 rough running help
b18b1 in a 93 hatch obd1. car was throwing code 10 intake air temp sensor found that the wires were bare just at the base i couldnt get a pig tail so i sealed them up, they were in good shape just the casing wore thru. cleared the code by disconnecting the ground on the batt and it threw it again so i tested the resistance of the plug at 40 deg it was like 1.4 wich is in spec i beleive as far as running like crap when its cold and i accelerate sputters and runs like **** when it warms up smooths out for the most part
Old Jan 25, 2011 | 06:41 PM
Nickeg9Ej1's Avatar
Default Re: code 10 rough running help
I've driven many cars with code 10 and it doesn't change running condition that I've have noticed, I'd try things such as cleaning iacv and fast idle easy to do and cost nothing. I had a d16z6 swap in a Ef that ran like crap when cold and the iacv had been completely filled with grime cleaned it and car ran 1000 times better.
Old Jan 26, 2011 | 08:24 PM
b93hatch18's Avatar
ya i took apart the iacv and the fitv and cleaned them it helped my hunting idle prob ive done all the tune up stuff to cap rotor plugs wires im wondering what else could throw that code cuz i cant see why it would for the actual sensor i fixed the wire and the sensor tests out
HdmPowered
May 4, 2009 01:41 PM
1337 Si
Oct 2, 2008 01:59 PM
trick_db
Aug 1, 2006 09:27 PM
TheHatchHog
16
May 15, 2003 11:26 AM
