Need help removing breather chamber!!! em1
I found out that my PCV Hose from the intake manifold isn't hooked up and got a new rubber piece to hook it up. Its a circle rubber piece that plugs into the breather and I cant for **** pop it on!! I am trying to take out the breather so I can easily pop it on cause there is no room from the top and I keep dropping it. Now From underneath the car I have unscrewed the 3 bolts, One from the top of the breather, one from bottom and third from the where the exhaust bolts on to. The breather moves easily but will not slide out! Can anyone please help me! ANy good guides? is it only 2 hoses connected to it?
Alright I finally got it out and the two hoses are connected. I had to remove an annoying *** bracket to get the breather out but now I can't even get the SOB in(the bracket in). It was only bolted on by 1 bolt after I got the bolt from the top part of the breather off. Seems like a pretty useless thing but do I really need to put it back in? Can I just have the breather bolted in by one bolt from the bottom? I'm just having a frustrating time getting the bracket in and aligned up.
Nation5
14
Oct 5, 2016 02:27 PM
crazyhouse2011
13
Sep 12, 2013 05:05 PM
delsolnewkid
Mar 11, 2006 04:12 PM
