What throttle cable??? GSR swap
Old Jan 24, 2011 | 08:21 PM
import-tooner's Avatar
Default What throttle cable??? GSR swap
What is the CORRECT throttle cable to run in an EK civic with a GSR swap?? I'm running the gsr cable right now but it seems to be too long. Maybe it could be stretched out??
Old Jan 24, 2011 | 10:16 PM
poloboy4's Avatar
Default Re: What throttle cable??? GSR swap
i just did my gsr swap i would hear people tell me to use a gsr throttle cable i used my stock ex cable and it worked just fine! ( i used the gsr throttle body and bracket it comes with.
Old Jan 25, 2011 | 01:01 AM
godluvstegs's Avatar
you are fine to just your stock throttle cable the hard part would be finding the throttle cable bracket to fit it properly if you know someone that can fabricate your fine. your just going to have to test a few types of brackets to see which one fits best.
Old Jan 25, 2011 | 05:30 AM
Okay, so what would the CORRECT cable be to use?? The GSR cable?
highliner82
Dec 1, 2010 05:35 PM
StoopidChris23
May 19, 2010 07:29 PM
Civichx1998
Nov 27, 2006 03:58 PM
HondAcura
Jul 19, 2005 05:20 PM
dynamo
Jul 4, 2005 07:41 PM
