need help with a ls swap into a ef with a hydro trans
Old Jan 24, 2011 | 06:11 PM
phaphon's Avatar
Default need help with a ls swap into a ef with a hydro trans
me and my friend are doing a swap and we ran into a problem.He has a cable to hydro swap mounts from hasport.Now the problem we are having is getting the L bracket to fit inbetween the motor and firewall mount.I was wondering do we need to bang the firewall in ? since we tried using the 90-91 ls L bracket and my 94 ls L bracket
Old Jan 24, 2011 | 06:37 PM
tonythetuner®'s Avatar
Default Re: need help with a ls swap into a ef with a hydro trans
You have to use the t bracket from the 94 and up integra. And it has to be for a manual bracket not auto cuz they are longer
Old Jan 24, 2011 | 06:41 PM
phaphon's Avatar
yea we tried that and still didnt fit i know its a 94 integra manual bracket cause i pulled it myself from my friends 94 integra which was a stick shift
Old Jan 24, 2011 | 07:03 PM
Are you using miss matched mounts is the motor sitting crooked?
Old Jan 24, 2011 | 07:12 PM
hatchet_honda's Avatar
is the rear t bracket not really sitting close enough to the crossmember mount to be bolted up? you have to hammer down the lip of the rear crossmember a bit so the bracket sits right.
Old Jan 24, 2011 | 07:16 PM
phaphon's Avatar
it says hasport on it and does not look like its sitting crooked
Old Jan 24, 2011 | 07:18 PM
you need to hammer down the lip on the crossmember. heres my engine bay. although i now have a stock d series rear mount on there, i did have a b16 in the car. the circled part is where you hammer it slightly
Old Jan 24, 2011 | 07:22 PM
phaphon's Avatar
are you talking about the bracket that holds the mount in the front on the crossmember?
Old Jan 24, 2011 | 07:23 PM
phaphon's Avatar
oh ok thank you for the info
Timothy Yhtomit
Dec 27, 2018 12:12 PM
No0by
Dec 28, 2010 09:25 AM
JokerTypeR
21
Nov 13, 2006 10:38 AM
Youlose1305
May 18, 2006 06:36 PM
Kamin
Jan 7, 2002 05:02 PM
