Suspension & Brakes Theory, alignment, spring rates....
wheel/hub maybe suspension issue
Old Jan 23, 2011 | 07:01 PM
cxhatch93's Avatar
Default wheel/hub maybe suspension issue
dont know if this is the right spot for this ... but i hope to get some help ..
i have a 94 db8 gsr
wheels: xxr 521 16x8 +20 offset .. tires: 195/45/16
suspension : stock shocks with no name coil overs ..
here is my issue .. i put on the wheels and noticed that the driver side sticks out about half inch or alil more causing me to rub the fender if i hit a bump .. now today i tried to swap out wheels thinking it might be that the wheel was made with the wrong offset .. but no.. its still the same..
also that in 1st 2nd and 3rd gear i get some vibration from the wheels when i accelerate .. they feel like they are not balanced but they are brand new and had the tire shop check them again all wheels and tires are balanced..
any help would be great thanks
Old Jan 23, 2011 | 07:05 PM
Nicefeet's Avatar
Default Re: wheel/hub maybe suspension issue
Axle nut tight
How’s is the wheel bearing
Has this car ever been hit
Aftermarket fender (I have seen a lot of aftermarket fenders that are poorly stamped aka too shallow or too wide)
Old Jan 24, 2011 | 06:52 PM
cxhatch93's Avatar
axle nut is tight ..
wheel bearing was pushed out alil when it was towed but the axle nut tighten back in
i have a jdm front end everything is oem
now it was hit on the drivers side but my roomie backed into in the driveway last year he just hit the bumper and fender
Old Jan 25, 2011 | 05:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My guess is that with that wheel, tire, and suspension setup, your wheel bearings and axles are most likely taking a dump on you.
Old Jan 25, 2011 | 06:13 AM
cxhatch93's Avatar
the axles are brand new .. the car has only been back on the road for two months .. im thinking the wheel bearings are causing the vibration .. im going to order new ones
but i still cant figure out why the driver side wheel sticks out more than the passenger ..
Old Jan 25, 2011 | 08:15 AM
Community Builder
Subframe shifted? I would ask if you've had an alignment lately, to verify left vs. right alignment readings, but I have to wonder if there's any place that would even touch a car with such a crazy wheel setup.
Old Jan 25, 2011 | 08:16 PM
cxhatch93's Avatar
thanks for all the help.. im going to check around some shops to see about a alignment .. i never had the car aligned since ive owned in 08 but it has been down most of the two years ive owned it .
civek97
Mar 14, 2017 05:10 AM
tianporn
Jun 5, 2011 10:19 AM
silverSOHC
Jan 3, 2007 12:00 AM
SIcivicHATCH
11
Jan 21, 2005 12:34 AM
Echo7847
10
Mar 30, 2003 03:52 PM
