#1 Cylinder rings are toast, honing ?
Old Sep 24, 2002 | 02:53 PM
filetofit
Guest
Posts: n/a
Default #1 Cylinder rings are toast, honing ?
Ok I've got 90-190-185-188 compression. It puts out blue smoke under acceleration, no other time. I assume it's the #1 rings or lands. My question is: Can I just hone the #1 cylinder and replace the rings and/or piston, or do I have to do all four. And also, I'm just going to hone not bore, it's a relatively new engine (40K) How many turns, up down strokes, of the hone so I don't take too much off?
One more question if I buy some low mileage used pistons that come with rings can I reuse them. Keep in mind this is a beater not a racer.
[Modified by filetofit, 12:14 AM 9/25/2002]
Old Sep 24, 2002 | 03:35 PM
b18c5turbo's Avatar
Default Re: #1 Cylinder rings are toast, honing ? (filetofit)
change ring all 4 cylinder
if piston is toast then hone it and change only the damage piston
Old Sep 24, 2002 | 04:03 PM
Flamenco-T's Avatar
Default Re: #1 Cylinder rings are toast, honing ? (b18c5turbo)
yeah, change all your rings....and repalce the toasted piston..
when honing do 12 QUICK passes up and down up to the edge of the cylinder wall....you should get a descent cross hatch then...
stan
1320london
Engine Machining & Assembly
Sep 17, 2016 12:00 PM
lude98SH
Dec 20, 2007 05:05 AM
qazaq
Jul 14, 2007 04:20 PM
jennsGSR
Aug 17, 2006 06:12 PM
myhatchrips
Nov 9, 2003 12:46 PM
