Transmission & Drivetrain Gearboxes, Differentials, Clutches
diff bearings
Old Jan 23, 2011 | 10:30 AM
ctr83's Avatar
Icon2 diff bearings
i have 95 gsr tranyy with tapered bearings. i am going to install mfactory lsd in it. now i am going to use ball bearings so it will be easier to shim. so do i use 98 gsr ball bearings and 80mm shim right?
Old Jan 23, 2011 | 11:54 AM
Aquafina's Avatar
Default Re: diff bearings
If you're using the B18C LSD then you use B18C ball bearings and 80mm shim. Year of the bearings doesn't matter.
Old Jan 23, 2011 | 12:13 PM
ctr83's Avatar
cool. thanks
Old Jan 25, 2011 | 08:25 AM
David @ Synchrotech's Avatar
OEM B18C ball bearing # 91005-P80-E31 and most commonly used 80mm shim is 41454-PL3-B00.
quickspool
Mar 17, 2011 08:18 AM
TB123
11
Apr 12, 2009 11:06 PM
B18CegHB
Jul 21, 2004 09:19 AM
jdmhatch94
May 20, 2003 08:02 PM
ZERO COOL
Jan 26, 2003 01:49 PM
