Crank pulley bolt...
Old Jan 22, 2011 | 12:32 PM
EJAYATE's Avatar
I Deliver
Default Crank pulley bolt...
Been spraying it with pb for about a week and using a 450 ft/lb impact on it with no luck. I went a bought an impact that does 900 ft/lb and its still not budging. I've used a torch and a breaker bar with a 4 foot extension on it too.... any suggestions?
Old Jan 22, 2011 | 12:34 PM
Mr.Cheezil's Avatar
Default Re: Crank pulley bolt...
i'd say just keep trying, it'll eventually budge.
take the torch to the surrounding area and just go nuts with the impact
Old Jan 22, 2011 | 12:44 PM
EJAYATE's Avatar
I Deliver
FInally got that ****. turned up the regulator a few psi and bam!
Old Jan 22, 2011 | 12:46 PM
Vizualaddiction's Avatar
Yeah those definitely can be a pain sometimes.
Old Jan 24, 2011 | 12:48 AM
bEEsKnEEs's Avatar
Heres the tool i made to loosen and torque crank balancer bolts. I took a large socket, welded tabs on two sides that fit the pulley, then ground off the ratchet side so i could hold it with a pipe wrench. Filed out the half inch drive hole till i could fit a half inch drive extension through it and put a 19mm socket on that. Works great for quick teardown and getting the correct torque on the pulley. I made it originally for a d series and then found it fit perfect in the b motors. Matco and snapon make something like this but its over a hundred bucks and i didnt have a dealer on hand at 3am that day.
Old Jan 24, 2011 | 04:46 AM
CivicxTree754's Avatar
Photogenic
Loved
Hey guy^^
Make another one and sell it?
Old Jan 24, 2011 | 05:02 AM
andyz's Avatar
I jammed a file in the flywheel and used a 4-ft gas pipe as a cheater. I broke my 17mm socket and bent one my softer 1/2 drive breaker bars before getting it off.
Honda actually make a 50mm hex fitting that holds the pulley and attaches to the FRAME
Old Jan 24, 2011 | 05:54 AM
KINGVEM^^ED6's Avatar
1600 ft/lb impact snap on FTW
Old Jan 24, 2011 | 07:55 AM
Rickdogg's Avatar
i used a 6ft breaker bar and a chain wrench they gottem at osh for $20 took me 2months to find one
bradley
13
Jan 9, 2012 02:12 PM
KCUF_DB8
Apr 2, 2010 09:18 PM
Baron55
Mar 2, 2007 11:00 AM
grngsr01
Oct 23, 2005 05:47 AM
Nocturnal
Aug 7, 2005 07:21 PM
