Failed Smog, running rich.
Old Jan 21, 2011 | 04:34 PM
Razster's Avatar
Icon2 Failed Smog, running rich.
Hello Honda Peoples,
I recently failed my Smog test, running too rich. (1988 CRX DX 1.5)
I adjusted the dizzy by hand and made the idle go from 1200rpm to about 600rpm
Adjusted the valves with the Honda book I use to have before I lost it.
Now, could any of these 2 things screw up my car bad enough to make my car run too rich?
I Really hate to get rid of the poor thing because I still get Insane gas-milage and enjoy the little thing too much to part with it.
I'm hoping it is just one of my screw ups and now something too expensive.
I replaced the DizzyCap/Rotar, Sparks Plus, No Spark plug wires, PCV valve (Not the hose though) and I did do a Seafoam run on it.
It has moments where if I floor it in first gear it shutter(stutters) but stops when I reach high RPM(2000+)
Any help would me MUCH Appreciated.
Thanks,
Raz
Old Jan 21, 2011 | 04:42 PM
Razster's Avatar
Default Re: Failed Smog, running rich.
Forgot: I changed the Fuel Filter too and Air Filter.
Old Jan 21, 2011 | 04:44 PM
wolfsbain's Avatar
i would also think about changing the oxygen sensor and if the wires look old just change them
Old Jan 21, 2011 | 04:58 PM
Razster's Avatar
When I was changing the dizzy cap and rotar, I did pull the spark plug wire from its metal boot and then re-attach. Would that make my car run rich though? I'm not very savvy on that portion.
Also, how the hell do I get the O2 Sensor off the header? I looked at it and returned the O2 (Was universal $28.00 Autozone special).
Would that Sensor be the big part of my issue? If so I might have to buy it back
Old Jan 21, 2011 | 05:08 PM
KINGVEM^^ED6's Avatar
yup buy it back and yup new plug wires will help ur in cali right? just pay for a "pass"
Old Jan 21, 2011 | 05:11 PM
Razster's Avatar
I wish I could pay for a pass, don't know the right mechanics to do so.
Yes I'm in Cali.
Also, yes I Seafoamed my car so I've been told that it will mess the O2.
Old Jan 21, 2011 | 05:22 PM
sanchoem1's Avatar
To buy a pass isn't cheap...
It could be your o2 sensor, but I wouldn't just start throwing parts at it. Have you checked the timing, and your vacuum lines(map sensor line)? Also where in cali are you?
Old Jan 21, 2011 | 05:41 PM
Razster's Avatar
Northern Cali, Near Redding.
I haven't checked my timing, is 800rpm too low? I don't have the book anymore, it vanished.
I guess I could have a mechanic check my vacuum lines, shouldn't be too much.
Old Jan 22, 2011 | 06:31 PM
crazyboy's Avatar
wat r ur numbers that were tested?
Mario Locatelli
Apr 3, 2014 06:34 PM
Juans_MX3
May 7, 2010 11:34 AM
b20vtech
Jun 28, 2007 07:38 PM
bkstudley001
Jan 22, 2004 07:30 PM
wizurd
Apr 20, 2003 11:31 PM
