Coilover Weights
Old Sep 24, 2002 | 01:46 PM
Flux's Avatar
Default Coilover Weights
Does anybody know the weights of the popular performance/racing coilover setups? Zeals, Buddy club, Tein, Mugen...
Old Sep 24, 2002 | 02:05 PM
yoshi234's Avatar
I shoot brides
Default Re: Coilover Weights (Flux)
darn, now that you mention it....
yshi - who shuda weighed the zeals
Old Sep 24, 2002 | 02:26 PM
tonyxcom's Avatar
Default Re: Coilover Weights (yoshi234)
Well, I can tell you that my Tein HA's were 4lbs heavier per shock/spring then my AGX with Ground Controls. I forgot the exact weight though.
Old Sep 24, 2002 | 02:27 PM
Asahi's Avatar
TEIN HA's with upper mounts weighed around 48 pounds on my bathroom scale
B2FiNiTY's Avatar
Default Re: Coilover Weights (Asahi)
What's stock?
Old Sep 24, 2002 | 02:32 PM
Kengs's Avatar
Default Re: Coilover Weights (ExOdy)
My Zeal Function S (for EK) weighed <u>under 6lbs each</u> if I remember correctly.
Asahi's Avatar
I would guess about 50 pounds as well. None of the lower end performance suspensions use lightweight materials.
Old Sep 24, 2002 | 02:42 PM
ITRinEJ1's Avatar
yeap any set of zeals function S+ will weigh in around 6-8lbs
my ohlins (surprisingly) was around 10lb; i was kinda expecting less
Old Sep 24, 2002 | 02:44 PM
B2FiNiTY's Avatar
Default Re: Coilover Weights (ITRinEJ1)
So coilovers would be considered unsprung weight?
Old Sep 24, 2002 | 02:45 PM
Flux's Avatar
yes...
tonyxcom's Avatar
Yes
Old Sep 24, 2002 | 02:46 PM
B2FiNiTY's Avatar
Default Re: Coilover Weights (tonyxcom)
Good good...just making sure.
Old Sep 24, 2002 | 03:17 PM
Smitdog's Avatar
Damn I want to go weigh my Buddy Club's now!
Old Sep 24, 2002 | 03:40 PM
tonyxcom's Avatar
Default Re: Coilover Weights (Smitdog)
Do it!
Old Sep 24, 2002 | 05:20 PM
AJ PwR's Avatar
My Buddyclub P.1 dampers with 18k springs weighs 7 lbs.
Old Sep 24, 2002 | 05:29 PM
Smitdog's Avatar
Default Re: Coilover Weights (AJ PwR)
Got to love the Buddy Clubs!!
A&J =
Old Sep 24, 2002 | 05:31 PM
bryan305's Avatar
i dissagree with them being unsprung weight. Some of the weight is supported by the bolts at the top, making it sprung....
Warren's Avatar
Wrong-Way Wang
Depends on the coilover design. Inverted shocks means less unsprung weight. OPM sells custom inverted setups.
Warren
Old Sep 24, 2002 | 05:37 PM
ZygSpeed's Avatar
What's the deal on getting some replacement (14K or so) springs for the Buddy Clubs?
Dave @ R&D has had mine "on order" since March or so, and I can't wait much longer before I put the BC's on the car. TIA
Old Sep 24, 2002 | 05:38 PM
Dr Pooface's Avatar
Is that 50 lbs a corner????
Old Sep 24, 2002 | 05:40 PM
B2FiNiTY's Avatar
Default Re: Coilover Weights (Dr Pooface)
Impossible...
Old Sep 24, 2002 | 05:43 PM
Tommy_Gunns's Avatar
If that is per corner. Getting a 6-8 lb setup would greatly reduce the weight of the car
Old Sep 24, 2002 | 06:21 PM
Dr Pooface's Avatar
Default Re: Coilover Weights (Tommy_Gunns)
Is someone going to confirm this?
My Bilstien/hypercoil setup can't weigh more than 12 lbs a corner.
Old Sep 24, 2002 | 06:48 PM
ZygSpeed's Avatar
I's NOT 50 lbs per corner!
Old Sep 24, 2002 | 07:32 PM
Asahi's Avatar
Default Re: Coilover Weights (Zygspeed)
Exactly. It is 50 lbs for all 4 shocks/springs/upper mounts.
stock ek
Suspension & Brakes
Jan 8, 2007 02:26 PM
JDM SLICK
39
Jul 24, 2004 12:31 AM
Chiller
Jun 24, 2004 09:27 AM
Hybrid ctr
Jan 15, 2003 11:12 PM
