OBD2 B series swap in EF
Old Jan 21, 2011 | 01:17 PM
vodkaTM's Avatar
Icon2 OBD2 B series swap in EF
Hey guys. I happened to get a 1995 B18b1 in a trade
And was wondering if anyone knew where a good OBD0 to
OBD2 swap partslist was.
Have a 1989 Civic Si hatch im trying to put this in...
so far i have:
B18b1 head/block/intake manifold
B18B1 DIZZY
B series axles
B series shift linkage
Type R LSD Tranny
Cable-to-Hydro conversion kit
GS-R brake rotors/calipers
OBD0 to OBD2 ecu harness
Still need to get B18b1 ECU.
Can anyone help me out?
Been havig lots of trouble finding info on this swap.
Old Jan 21, 2011 | 01:31 PM
crx_si-r's Avatar
Default Re: OBD2 B series swap in EF
Why do you want to run it as obd2? Especially on a stock LS? just run it as obd1, which is what a 95 b18b is anyway.
Old Jan 21, 2011 | 02:34 PM
vodkaTM's Avatar
I thought the 95 LS was OBD2... ?
Old Jan 21, 2011 | 03:19 PM
crx_si-r's Avatar
No, 96+ is obd2. 92-95 is obd1
Old Jan 21, 2011 | 03:38 PM
tonythetuner®'s Avatar
ya man 95 is still obd1 lol you do not need the Obd0 to obd2 jumper sell it and get a obd0 to obd1 jumper also need the b series mounts for the ef and eaither get the ef b series shift linkage or cut the integra one shorter sounds like you got everything else you need besides the 3 things I said oh and the ecu
Old Jan 22, 2011 | 03:47 AM
hammergunner's Avatar
so far i have:
B18B1 DIZZY
B series axles
Type R LSD Tranny
well you seem to have everything, but you dont need GSR brakes or rotors in fact any 92 and up suspension will toss your camber off BADLY you need The Integra DA hubs if you want bigger brakes, But you said its an SI, so the B-series axels should just pop right in for that model. And you need an OBD0 to OBD1 Ecu jumper as well as the a OBD1 B18 dizzy.
MAKE SURE DIZZY AND ECU OBD match you can't use obd0 dizzy with an obd1 ecu same goes for OBD2
vodkaTM
Jan 21, 2011 07:14 PM
clayton bigsby
Northwest (Sales)
Aug 9, 2005 10:55 AM
FkingSUV
Aug 29, 2004 06:10 AM
ID_ten_T
Dec 21, 2003 10:35 AM
