good spark plug
Ether the NGK PZFR6F - 11 or a Denso PKJ20CR-L11 work great for an H22.
What is your current engine setup, is it stock or modified? You will need something different if you are boosted or running a higher compression naturally aspirated setup.
The NGK Iridium IX is a superb plug if you are looking for something long-lasting..
If you want a cheaper option that will perform just as well, try the NGK G-Power.. Its about $2.20 each and is a superb plug
That said, im too lazy to change often so I use the Iridium IX myself
RACEPAK
Sep 21, 2005 04:08 AM
