Suspension & Brakes Theory, alignment, spring rates....
ITR lower control arm question
Old Jan 20, 2011 | 05:27 PM
rsa0905's Avatar
Default ITR lower control arm question
Im picking up a set of Tein SS from a friend of mine for my gsr. They are ITR spec, but i am getting the ITR lower control arms as well. The ITR lcas would go right in place of the gsr lcas correct? Meaning there is no length difference between the two? Also, do the bolts that go through the subframe and hub on the lcas seize up as bad as the ones for the shock mount? Thanks for the help!
Old Jan 20, 2011 | 07:13 PM
Tyson's Avatar
Default Re: ITR lower control arm question
the geometry is the same.
Old Jan 20, 2011 | 08:06 PM
rsa0905's Avatar
Thanks man
ITR0529
Sep 4, 2007 10:14 PM
vbspec
Aug 31, 2004 01:16 PM
an2ny888
Oct 24, 2003 08:13 AM
JSJ EG6
Nov 10, 2002 10:31 AM
