itr trailing arm beefier?
i was told that the itr trailing arm is reinforced as compared to regular EG trailing arms, and that it has a more pronounced curve, resulting in a wider rear wheel track. can anybody confirm this?
Re: itr trailing arm beefier? (an2ny888)
wrong.
actually it is less rigid and can potentially provide a passive steering effect under high cornering loads to allow smoother transitions during cornering.
qwazy huh?
qwazy huh?
Re: itr trailing arm beefier? (owen_the_soyboy)
They might have been referring to the ITR rear lower control arms which are significantly different from EG's/other Integras.
Re: itr trailing arm beefier? (AcidGord)
actually i was referring to the trailing arm, but i was also wondering about the lower control arm as well. you see im from the philippines and all the civics here use the itr style lca. from what i see in the junkyards here the EG and ITR lca's are the same, its probably just the bushings that are different. i was told that the itr trailing has reinforcements welded on, i'll have to check the junkyards again to verify this
EDJames22
03-08-2008 07:05 PM
skribblah
07-26-2003 12:14 PM
