What kind of battery do you use?
Old Jan 19, 2011 | 07:23 PM
The_Head's Avatar
Default What kind of battery do you use?
I'm seeing a pretty wide price range for motorcycle batteries, so I was wondering what brand do you get?
Old Jan 20, 2011 | 08:44 AM
"A"'s Avatar
"A"
Default Re: What kind of battery do you use?
I find the cheapest online, with regular maintenance never experience any battery failure on my motos, even on my Chinese scooter's OEM battery. Winter time when temps. can stay below freezing for a week to ten days, I just keep the batteries charged up every few days.
Old Jan 20, 2011 | 10:19 AM
The_Head's Avatar
Yeah I was kind thinking along those lines. The site I found Yuasas on had them super expensive, over $100. Might as well get a $29.95 battery, and you still come out ahead if you have to replace it in a few years. I dunno, still need input.
Old Jan 21, 2011 | 11:24 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
for a cheap beater bike ill just run a 30 dollar battery from walmart.
i run a speedcell ss battery for my 600rr, weighs 1lb, lol. alot of people are making these batteries for the same price or cheaper than your average yuasa battery so u might as go with the lithuim cause there light as hell and give u more room under your seat...
http://www.motowheels.com/italian/my...r=&collection=
Old Jan 22, 2011 | 06:50 AM
Kista20's Avatar
http://www.tristatebattery.com/
They sell motocross brand which is made by yuasa and I've gotten three different batteries from them for my dirtbike, atv, and also a friend's atv. Never had a problem.
Yuasa is the prob. the best battery you can get and is the oem's choice from factory.
Old Jan 27, 2011 | 10:02 AM
The_Head's Avatar
I caved and got a Wal-Mart battery for it. $30. It was about 3/4" shorter than the old battery so I had to make a cardboard pad to raise the battery back up to reach the cables, lol.
Old Jan 29, 2011 | 09:04 AM
cockerkid008's Avatar
Bikemaster Tru Gel
longer warranty then regular batteries
no acid to leak
Old Feb 1, 2011 | 12:31 PM
TwoWheelz's Avatar
Lot's of different thoughts on battieries. No doubt that Yuasa makes the highest quality battery. I have seen them last 15 years! Yes they are expensive in most cases they are worth it. The new Bikemaster True Gel battery is proving itself and seems to be priced right, but not available for all applications. If your bike sits alot between rides Yuasa seems to have an advantage. The use of a battery tender during storage is a huge help!
Matt
Old Feb 1, 2011 | 04:32 PM
The_Head's Avatar
The OE Yuasa in my 2008 Zuma only lasted 2 years. Not sure what happened there. I fire up my 2 wheeled vehicles regularly in the winter to keep the batteries up.
Old Feb 3, 2011 | 05:10 PM
Kusai.Nihonjin.Desu's Avatar
I use MOTYDesign's 8 cell for my 600 - very lightweight. Didn't have the greatest customer experience with him, however.
The RC is on OEM, I figure they are good for a couple of years - I'd change them out even if they are still cranking. I've been left stranded in the mountains before with a sudden crap out.
Old Feb 3, 2011 | 06:06 PM
Blindstuff's Avatar
Cheapest chinese knockoff I can find, I just use a battery tender and they last about 2 years.
Old Feb 3, 2011 | 07:39 PM
Kiwibird83's Avatar
Reigning GDD Queen
I'm a big fan of the lead acid kind personally.
Old Feb 5, 2011 | 11:26 AM
wesvailco's Avatar
-i had one on the ducati, learned the hard way with use of a trickle charger.
-now use 8(eight) A123 Systems LiFepo4 lithium-ion cells in a plastic carrier wrapped in duct tape. 550g. they'll last a full year with no charge, 15min 12v/2amp charge is all that's required.
Old Feb 22, 2011 | 04:05 AM
Fuuma0083's Avatar
I run a interstate wet battery. I will never run any kind of gel cell battery because after it dies once its pretty much done for that battery
Old Feb 22, 2011 | 01:57 PM
Kookz's Avatar
Resident Vagabond
8 Li-Fe-Po4 as well. Absolutely the way to go until it gets close to freezing. It only takes me about 30 seconds to pop the seat and disconnect the quick disconnect, and I pop it in my pocket if it's below 40F. Otherwise, it starts even after leaving the bike sitting for 3 months (which I do often, working overseas).
Old Feb 27, 2011 | 11:05 AM
Loco Honkey!'s Avatar
Speedcell in both my RC51 and my F4i.
Old Feb 27, 2011 | 02:19 PM
Rtzx9r's Avatar
GDD 1%
Yuasa on a bettery tender. I top off the water every few months as well.
welder
Honda Ruckus and Scooters
Aug 24, 2023 08:52 AM
crazes
Jan 27, 2013 06:46 AM
ee-gsr
Honda Motorcycles
Oct 17, 2004 10:53 AM
buzlink
16
Dec 13, 2002 12:25 AM
