Started tuning my built b16 today questions
Old Jan 18, 2011 | 05:15 PM
tobster's Avatar
Default Started tuning my built b16 today questions
Ok my setup listed below
b16A2 bored 81.5
11.5 je pistons
eagle rods
brian crower stage three cams
brian crower dual valve springs
93 oct fuel
p28 started off using p72 base map
Tuning on crome pro
thats all you should need to know for the following questions
1. my mbar at idle is around 600- 640 is this correct?
2. my idle starts in the middle of the base map wierd?
3. my tps is reading -4 - -5 % ?
Old Jan 18, 2011 | 05:21 PM
tobster's Avatar
Default Re: Started tuning my built b16 today questions
also if anyone has a map already made up that would be close to what i have that would be awsome then i wouldnt have to change to much
Old Jan 18, 2011 | 06:42 PM
mouab18c1's Avatar
1) yes that's correct
2) Where in the middle?
3)Have you calibrated your tps on Crome pro?
Most important upgrade to a better tuning program!
I would also try a b16 map first.
Old Jan 18, 2011 | 07:06 PM
tobster's Avatar
uploading photo now taking a min sorry i didnt know you can calibrate tps in crome lol ill look into that
Old Jan 18, 2011 | 07:27 PM
HAMOTORSPORTS's Avatar
Yes, with those cams you'll have a lot of overlap. This lowers intake vacuum (or increases pressure in the manifold if you want to look at it that way). Since you have less vacuum, your Manifold pressure readings will be further to the right on your map.
Old Jan 18, 2011 | 07:43 PM
tobster's Avatar
thanks guys im still trying to get this pic up so you can see where she idles im going to start with b16 map tomorrow and see what i get going there
Old Jan 18, 2011 | 07:46 PM
tobster's Avatar
where abouts is the tps calibration i see the non honda tps calibration thats it tho
Old Jan 18, 2011 | 08:27 PM
mouab18c1's Avatar
I'm not sure if CromePro has the option but on Neptune you can.
Old Jan 18, 2011 | 10:44 PM
cloviskilla's Avatar
normal with big cams. adjust your tps with a volt meter.
Old Jan 19, 2011 | 04:32 AM
tobster's Avatar
cloviskilla tps is non adjustable i dont think its zero in crome somewhere
Old Jan 19, 2011 | 04:34 AM
tobster's Avatar
i was just told from a guy with rocket motorsport mx24 or whatever he is around 450 mbar these cams could be a tad smaller i guess but shall i proceed with the tune
Old Jan 19, 2011 | 07:01 AM
You may want to check your cam timing. Adjusting the cams for less overlap may increase manifold vacuum as well (but you may loose power if not right)
Old Jan 19, 2011 | 07:51 AM
tobster's Avatar
same thing he said timing marks dead on distrbuter timing im checking on lunch in a hour crower claims these cams preform the best at 0 degrees so im using stock cam gears can distributer timing make this happen?
Old Jan 19, 2011 | 07:52 AM
tobster's Avatar
im tryn to get it somewhat ok to drive to continue breaking it in and bring it to tuner to be dyno tuned
Old Jan 20, 2011 | 05:34 PM
tobster's Avatar
well got it figured out and with those cams my mbar is around 350 at idle even better now to street tune and get her to the dyno woo hoo
Old Jan 21, 2011 | 12:36 PM
popwars123's Avatar
i know that its going to be different for every setup, but my crower stage 3's made the best power on the dyno at +4 intake, -2 exhaust.
jonman27
Engine Management and Tuning
Oct 6, 2013 05:39 PM
bmxkills
Apr 24, 2011 11:11 AM
tobster
Jul 27, 2010 04:38 PM
FERIOkid
Nov 11, 2006 04:07 PM
Nerologic
Oct 4, 2003 11:03 PM
