How much is a typical compression test supposed to be?
How much at Sears??!? (Sale!)
Honestly, now. How difficult is the compression test for the we-todds of the world like me?
Make sure you take all the plugs out,then test one by one.You'll get a more accurate reading this way.If you have a leak and leave all the plugs,it will not show a leak since all the other plugs are holding the compression.
Oh yeah! that is way too damn much for a few minutes of work.
[Modified by JDMITR222, 1:08 AM 9/25/2002]
If you can remove a spark plug and disconnect an injector clip then you can do a compression test
ndont disconnect the injector's, you need to keep wot while doing compression test! eric
